Behringer europower pmh5000 turn it on big flash and smoke came out of vent no longer works did smell hot when it was last used
  • 4,234 Answers
The output section has shorted output transistors. The increased load on the driver section probably smoked a few capacitors and resistors. Until the unit is repaired, you won;t get anything out of it. I would figure on $25-$50 in parts for the repair plus the local labor rate.
Dan
Posted on Oct 07, 2008
Need a power supply for a behringer pmh5000 help
Posted on Jun 10, 2013
I have a behringer pmp5000. At Practice one of the cables was stepped on and came out of a speaker.then, plugged back in immediately. There was some smoke and now the unit wont even turn on. Can this be...
Yes, it can be repaired. Likely at least the output transistors are fried, possibly the drivers are too. Possible other components like resistors gone, too. Needs somebody that knows amps.
Jan 20, 2015 | Behringer Europower Pmp5000 Powered Mixer...
Behringer EUROPOWER PMP1280S smokes
If you mean that smoke is coming from the equipment, it's time to unplug it and get it serviced. This typically means that a component has failed - it can usually be identified because it will be physically deformed. You might see a crack in an IC, a burned resistor, or something similar. Often, though not always, the component that failed may not be the only defective component on the board - for example, a voltage regulator may fail, but it might be due to a faulty capacitor, or some other short-circuit on the board. It's best to refer the repair to someone who is skilled in troubleshooting.
Mar 08, 2014 | Behringer EUROPOWER PMP1280S Powered Mixer...
Channel 2 protection light on in ep 4000
Will be no doubt the main power amp that has failed that is connected to that channel. It will be located on a big heat sink and be hotter than the other(s) channels if you go in after it's been on.
Dec 11, 2013 | Behringer EuroPower EP4000 2Channel...
Need a power supply for a pmh5000 and install directions
These are delivered with a power supply. If yours has failed, LIKELY there are other problems. I have repaired several supplies and can coach you through which parts to replace. Often the failure originates with a shorted MOSFET in one of the amplifier channels, usually the rearmost one. Getting parts for these is really hard as FullCompass is the Behringer parts distributor. The SPS1000 supply takes out about $25 of parts when they go. The hardest parts to replace are the IGBT transistors as the heat sinks are hard to remove to get the screws out of the transistors. All the repair parts are available using five different online sources.
Sep 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My europower pmp 2000 powered mixer wont turn on and the fuse appears good. I turned it on and it immediately turned off ,nothing smells burnt. any ideas on what it could be
This is likely a power supply failure, possibly brought on by a failure of one of the amp channels.
This is probably close to your supply:
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
Scroll down to "get manual" and click on that to download schematic. Ignore other download links.
Aug 05, 2011 | Behringer Pmp2000 Europower 800w 10ch...
I purchased Behringer Euro PowerPMP1680S through Amazon.com from USA. I live in India. not knowing that it is 120V i connected it to 240v supply. after switching the on button, two times sound came along...
Probably did major damage to the power supply. Likely the IGBT's are gone, the switching regulator and one or more of the 4 driver transistors and the speedup diodes and probably the ceramic charging resistors.
This will be close to your schematic: http://elektrotanya.com/behringer_europower-p0569_hca2400_sps1000_dpx_pmp-1280s_5000_sch.pdf/download.html
Scroll down to "get manual" and click on it to download. IGNORE other download links.
Repair of this is NOT for those unskilled in electronic repair. When restarting after repair, insert a light bulb in series with the power. You will need to use a step-down transformer to run this unit.
Jul 30, 2011 | Behringer Europower PMP1680S 1600-Watt...
I need the diagram of behringer europower pmh1000
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
200 people viewed this question
 Grubhead
Grubhead
