Question about Kyocera FS-2000D Laser Printer
Urgent printer is saying unknown toner and not printing anything
SOMETIMES IF YOU UNINSTALL AND REINSTALL THIS COULD RECTIFY THE PROBLEM. OTHERWISE CONTACT YOUR PRINTER BRAND NAME CO. AND ASK FOR THE SOLUTION TO THIS QUESTION IF STILL UNDER WARRANTY AND GUARANTEE TAKE IT BACK AND GET IT EXCHANGED OR FIXED.
HOPE IT MIGHT HELP
BARB C.-PC SPECIALIST & MULTIMEDIA
Posted on Oct 07, 2008
Mfc 7860 dw - replaced toner but still says
Crazy,
check the toner, probably there are some lids or tape you need to remove.
Jun 28, 2012 | Brother MFC7860DW AllInOne Laser Printer
Getting unknown toner level message on a Dell1710. Will not print anything. Thanks Owen Locke
Remove the toner cartridge from the printer and shake it. Does it have toner in it? Can you hear anything or does it feel heavy enough to believe that it is not empty?
Shaking also resituates the toner in the cartridge.
Turn the printer off. Put the toner cartridge back in it. Disconnect the printer from the computer and unplug the power supply for about 2 minutes. Plug the power back in first but dont turn it on yet. Connect to the computer and then turn the printer on. See if this gets rid of your error code.
If it doesnt get rid of the code, then replace the toner cartridge.
The problem is that the printer is not registering any toner inside the cartridge although the computer chip on the cartridge is saying that it is fairly new and should not be empty yet. When this happens, there is no other choice but to replace it.
Sep 27, 2010 | Office Equipment & Supplies
Need to use the printer machine in black and white as missing yellow toner waiting for it but machine is blocked and need urgently to print docs. Pls help me
Unfortunatley most printers will not allow you to print if one of the colours are missing or empty.and so you will need the yellow toner to be replaced before you can print. there is a way that sometimes works and that is to remove the toner cartrige and give it a good shake this evenly distributes the toner inside and sometimes make the printer think it has enough toner and allows you to print. As I said this only works sometimes and is not a perfect solution
Jul 01, 2010 | Office Equipment & Supplies
How do i override an empty color cartridge so that I can atleast print in black?
There is an error in the control logic of the printer that you can exploit like this:
  1. Start printing your document, you will receive the error message "missing toner"
  2. open the front door and close it again, this will reinitialize the test cycle
  3. the printer will now print one page before verifying the toner content again
  4. after one page you get the"toner empty" message again. Reopen the door and close it again to print another page.
This is only an emergency workaround if you really need to print something black urgently, in the long run you still have to buy a new toner.
Apr 15, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Says load toner
check your user manual to see if you did everything ok... also check the troubleshooting and maintenance sections
Dec 23, 2009 | HP Color LaserJet 2600n Printer
I am using samsung ml 2245 monocrom printer.. after printing 2*** print with the demo toner... it stop working and giv the error of toner exhuated..i refil the toner only single time.. plz tell me how to...
We have software to reset your printer
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Jun 11, 2009 | Samsung ML-1640 Monochrome Laser Printer
Need advice urgently
Try to search for this part numbers: H3730 or J3815 or K3756 or N3769 on http://ebay,com.my
I'm sure you'll find a lot of ink toners to buy....
Nov 07, 2008 | Dell 1710n Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Problem for scx 4100 printer
the fuser is the part that melts the toner on the page if you open the door on the back the part you see with the two rollers ione is orange the other has a teflon coating on it this is the fuser. they are no longer available
Jun 23, 2017 | Samsung SCX-4100 All-In-One Laser Printer
Samsung scx 4216f all in one printer
Searching on Google on how to access the fuse I found a page that showed you how to reset the counter without replacing the fuse. It was simple, access the TECH menu and select NEW CARTRIDGE. Here are the instructions:
[menu] - [#] - 1934 - [menu]
Then select “NEW CARTRIDGE”
Restart Printer to get out of the TECH menu.
May 11, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Kyocera FS-2000D Laser Printer Logo
96 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
