Question about Garmin Forerunner 305 GPS Receiver
Recently purchased a edge 305cadenec/heart rate monitor.cadence is not coming up on the monitor. every thing else is working. Pushed the reset button on the sensor the speed light was fine the cadence light seem to be missing now and then,the magnet seems to be in the right place.
  • Anonymous Mar 16, 2014
    Recently purchased Garmin Edge 800 and had no problem setting it up with the Garmin hr monitor and speed/cadence sensor. I thought all was well until I rode the bike and realized that the Edge was doubling my road speed and hence miles covered as well. It would occasionally momentarily flash the correct speed but would bounce right back to double where it was 99% of the time. Unit was also pausing momentarily and then immediately resuming. This Edge 800 is new but I have one several years old that I use on another bike and when I tried that older unit on the new bike it did the same thing, doubling speed and mileage and pausing and resuming frequently. Is there anything in the set up process that I missed and that would cause both units to do the same thing? Any suggestions would be appreciated.
  • Anonymous Mar 27, 2014
    How do I pair a wahoo heart rate monitor and wahoo speed and cadence sensor to a garmin 510
  • 3 Answers
Suggest you first try changing the battery in the sensor...then reset, then rescan for it on unit. It seems like quite a few have been shipped with dud batteries.
Posted on Nov 28, 2008
Garmin 800 will not charge / come on?
It's like the gps will not pick up a signal. It scene has been frozen for weeks now
Aug 25, 2014 | Garmin Edge 800 GPS-Enabled Cycling...
How do i do a factory reset
some error is normal. You need to state how much as a percentage. 10% 50%?
Apr 15, 2014 | Garmin Edge 705 GPS-Enabled Cycling...
Its stoped reading the cadence sensor
First check your settings and make sure that cadence is turned on. Then:
#1) check to make sure that your cadence sensor has not moved and is still within 1-2mm of the magnet on the crankarm.
#2) make sure you still have a magnet on the crankarm.
#3) if #1 and #2 are good, does a little red light come on (body of sensor) when the crankarm magnet pass the sensor.
If all these things have been satisfied and you still do not get a reading, then you have a dead battery and you need to replace the sensor.
Dec 05, 2010 | Polar CS100B Cycling Computer Heart Rate...
Heart rate reading low
try this link for the manual.
polar f11 heart rate monitor manual Google Search .
However, you may wish to reset the unit and start over with new settings. You can resetyour Polar F11 by following a few easy steps. Press any button to activate the Polar F11 Fitness heart monitor unit. Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button.
How to Reset a Polar F11 ' Healthfully reset polar f11 heart rate monitor Google Search
Oct 29, 2017 | Polar F11 Heart Rate Monitor
Will the garmin edge 705 provide/ be able to produce a power watt measure during outdoor rides and what do i need to purchase to be able to get this information?
The 705 comes in multiple versions from basic that will give you heart rate to a team garmin version that has the cadence, speed, calories, etc. As for power meters the 705 is 3rd party compatible to show you watt measurements.
The following third-party ANT+Sport-enabled power meters are compatible with the Edge 705:
  • iBike
  • PowerTap
  • Quark
  • SRM
May 12, 2009 | Garmin EDGE 705
I just bought the Edge 705 with heart rate. I have done everything to get the display of heart rate to come up on the screen but nothing is working. I've tried wetting the sensor on the strap, standing...
Menu>Settings>Data Fields>Bike Computer #>Press Stick>Select Field where you want HR to Display>Press Center Stick>Scroll to HR>Press Center Stick to select. et voila.
Mar 24, 2009 | Cadence Garmin Edge 705 With Speed And...
Garmin Edge 305 HRM problem
Try to pair his unit with your strap and it won't work, you have a bad strapl
Feb 16, 2009 | Garmin Edge 305 GPS Receiver
Distance and average speed don't compute.
My solution included changing the battery in the cadence sensor (GSC10). You might not need to.
1. After changing battery, take bike outside. Turn on Edge 305 to acquire satellites (might not be necessary..)
2. Press reset button on GSC10. Should see red/green flash.
3. On Edge 305, go to SYSTEM.
4. Scroll down to ACCESSORIES.
5. On Accessory page, scroll to bottom, under Cadence Sensor, and press RESTART SCAN.
That fixed my Edge 305 - cadence and speed do appear now.
Apr 07, 2008 | Garmin Edge 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
235 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
