Question about Sony PlayStation 2 (PS2) Console
PS2 format disc
When I want play [Metal Gear Solid 2 (Substance version) and 3 (Subsistance version), consol ask me to insert "format disc"
PS2 was working fine.
    Guru:
  • 1,894 Answers
Did you insert any bad disk in that?
please try cleaning the lens using the lens cleaner
Posted on Oct 07, 2008
  • 1 more comment
  • dewan nafees ahmed Oct 07, 2008
    The disc it is asking for is not one that will format (erase, etc...)
    the machine. You are likely getting this error because your PS2 is
    having difficulty reading the one you have in there, if there is one
    present at all. Try cleaning the disc with the proper cleaning suplies
    recommended by SCEA. You may need the disc repaired too. I like to
    gently wipe the disc (with non-fiberous material) and continue trying
    it. Eventually, it may work.
    If you are recieving this error, it is because one of two things is
    happening, your hard drive is errorneus and needs to be formated. Or,
    the more likely, your PS2 thinks you are inputting a disk that is not
    in a format the PS2 recognizes. A PS2 disk is in *.ELF format, and a
    PS1, I believe is *.ISO. A PS2 can read both, and DVD's and music CD's,
    though it has trouble playing all tracks on a burned CD, and can not at
    all recognize an MP3 disk, without a mod-chip.
    The PS2 can give this error when it can't read the disc, its just a
    form of DRE, there is no such thing as a PS2 Format Disc, it is just
    asking you to put a disc in that has a format a PS2 disc can read, i.e
    a normal PS2 disc.
    Try cleaning the lens again, check a few of the tutorials around the
    net to make sure you are using a good lens cleaning fluid and that you
    have cleaned the lens fully,(requires removing the plastic laser cover)
    and then try adjusting the laser position.
When i insert a god of war platinum disc in my ps2 it shows please insert playstation or play station format 2 format disc.why
You may need to take apart you PS2 and rotate the white gear about 1/8 of a turn or so and test with just the DVD lid on before you put it back together. If you still get the error try another 1/8 of a turn and so on. Detailed instructions and pictures can be found here on how to take apart your PS2
http://www.tweak3d.net/articles/ps2repair/4.shtml
Jan 12, 2013 | Sony PlayStation 2 Slimline Console
Ps2 Disc won't respond to a Ps3 when inserted.
Only the first version of the PS3 had PS2 backwards compatibility, They did make a special edition Metal Gear Solid version with it included but other than that no other PS3 will play PS2 discs... No matter what Add-On you install.
Oct 07, 2012 | Sony PlayStation 2 (PS2) Console
How to fix rsod on pcsx2 0.9.7
The infamous Red Screen of Desk -- A.K.A. Insert a Format Disc screen.
This screen is NOT asking for a disc to FORMAT the PS2. What it IS asking for is a PS2 or Playstation format [or a better word -- PS2 or Playstation TYPE disc. A disk with Playstation 1 or Playstation 2 type software on it -- in other words, a ps1 or ps2 game]. It's basically asking for a CD or DVD with software that the playstation can play. This red screen occurs when you insert an XBOX game or a burned/copied PS2 or PS1 game. What the PS2 is stating is that is cannot play this format [or type of] disc. It's asking you to insert a format [or type of] disc that it can recognize and use.
The most common reason for this screen appearing, if your PS2 does NOT have a mod chip, is a dirty lens. Try cleaning your lens and this should go away. What happens is that the lens becomes dirty and does not recognize the disc you inserted as being a PS2 or PS1 format [or type of] disc. So it's asking you to insert one. If your PS2 does have a mod chip installed, it could be a problem with the chip or the disc you burned. We don't install or sell mod chips, so we can't help you with that one.
May 20, 2012 | Sony PlayStation 2 (PS2) Console
How to fix rsod in pcsx2 0.9.7
The most common reason for this screen appearing, if your PS2 does NOT have a mod chip, is a dirty lens. Try cleaning your lens and this should go away. What happens is that the lens becomes dirty and does not recognize the disc you inserted as being a PS2 or PS1 format [or type of] disc. So it's asking you to insert one. If your PS2 does have a mod chip installed, it could be a problem with the chip or the disc you burned. I don't install or sell mod chips, so I can't help you with that one...
My son's ps2 asks for a ps2 format disk and I'd like to know if there's a site where I can download it for free
Hi there, what your PS2 is actually asking for is a PS2 disc of the correct format, not a disc to format your PS2. Usual causes of this are :
1. Laser faulty or dirty discs.
2. Trying to play a copied game on an unmodified console.
3. Trying to play a copied game on a modified console where the copied game has been burnt to the incorrect disc type
4. Trying to play a disc from a different region, i.e a disc from the US will not play on a UK console.
Hope this helps
Dec 11, 2010 | Video Game Consoles & Games
Asking please insert format disc when trying to play a new game
The game you have is not being recognized by your ps2, you need to make sure that your ps2 is modifed to be able to play ALL ps2 games through out the world. Or if your ps2 is modified already then its a bad disc copy.
Jun 10, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Loading & Playing
change you'r ps2 lence ribon.-goodguy electronics-sri lanka -094785180737-
Aug 20, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
125 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
