Question about Video Cameras
Canon Handycam recorded DVD cannot be played back !
A 80 mm DVD-RW was recorded in a Canon Handycam.It can be played back on the Handycam only.When loaded in a DVD player or a Computer DVD drive it is showing empty / no disc !
Heres what u should do. Attach its charger and switch the power on. Then start the cam and press the function button and go to finalize in the menu. it will take a few minutes and its done. Play it anywhere now... Cheers...
Posted on Jun 07, 2010
Finalize the disc. Use the feature button to access the menu. Camcorder must be on external power supply to finalize the disc.
Posted on Jan 21, 2009
I have same problem as posted by josephtapos on october o7 2oo8. cant play back my recorded video on my laptop. I check the manual but there is no instruction on how to finalized my video. i hope you could help me find a way to solve my problem as soon as possible.
Posted on Oct 31, 2008
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
How do you delete videos from your sony handycam DCR-DVD405
This Sony camcorder uses mini-DVDs to record and there are certain restrictions when DVD is used, it is not like videotape. For a DVD-R disc, you cannot delete video once it is recorded because this type of disc is a record once only. Depending on which other disc type you use and how it was initialized, you MAY be able to delete video. For a DVD+RW disc, or a DVD-RW disc initialized in VIDEO mode, you can delete the last scene IF you have not removed the disc and not recorded any new video. For a DVD-RW disc initialized in VR mode, you can delete anytime. And here is how:
Turn on camcorder and press PLAY. Select the video or still image tab that contains the data you want to delete. Touch EDIT. Touch DELETE. Select what you want deleted. The selected scene is marked with a checkmark. Press and hold the image on the LCD screen to confirm. Touch RETURN to go back to previous screen. Touch OK - YES. You cannot recover data once deleted. There is also a DELETE ALL to delete all video or images.
Mar 22, 2011 | Sony Handycam DCR-DVD405 Camcorder
How do I get Handycam DCR-DVD305 to recod videos onto a memory stick duo pro?
It is not possible to record the videos onto a Memory Stick Duo or Pro Duo, as this Camcorder DCRDVD305 does not support video recording onto the Memory Stick.
To record the videos you may use 8cm DVD-R/DVD-RW/DVD+RW.
Aug 23, 2010 | Sony Handycam DCR-DVD305 DVD Camcorder
Dvd-r or dvd-rw discs not recognised
my computer not reconocing tha sofware of my camera, not open fails.disk of sofware is error help me please
Aug 12, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Vrd-mc5
there is a firmware fix on the sony website
VRDMC5 System Software Upgrade Important Notes: New Features:
1) Allows VRD-MC5 to record video directly from a MemoryStick Duo memory card recorded using a Sony's MemoryStick Handycam Camcorder or an HDD/DVD Handycam Camcorder with Hybrid recording capability. Supplemental Operating Instruction
2) Allows VRD-MC5 to record video incrementally from multiple recording media in a Sony's Handycam Camcorder with Hybrid recording capability.
Improvements:
1) Fixes recording problem with no audio using a Digital8 Handycam Camcorder recorded through IEEE-1394 or i.LINK connection.
2) Corrects signal detections with a MiniDV Handycam Camcorder as copy-protected.
Version: 30R2 File Type: zip File Size: 4.11 mb Date: 01/06/2008 Download & Installation Instructions: Please download the attached VRDMC5 System software update file (SNDF8U30.DA2) and unzip it in a folder of your choice on the computer. Also print and read the attached instructions prior to executing the System Software Update.
Attachment Size VRDMC5 System Software Updater.zip 4.11 MB VRDMC5 System Software Update Instructions.pdf
Mar 29, 2008 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Sony DCR-DVD 108 disc won't play or record
Movies shot DV Camcorder forms mpg files when down loaded in computor and can not be converted to a CD. Problmes comes in conversion of mpg files to AVI, WMV, AVSEQ or MPEG2 etc.
Oct 29, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
When should I use a DVD-R / DVD-RAM / DVD-RW?
Write Once – After finalizing, a DVD-R disc can be played back in approx. 95% of home DVD players and PC DVD drives Capacity – 30-60 minutes (depending on the selected filming mode) of high quality motion video can be stored on a single of a disc. Re-writeable – DVD-RAM allows for recording and re-recording of movies and still photos up to 100,000 times per disc. DVD-RAM is like a removable hard drive. Compatibility for video playback of DVD-RAM in standard home DVD players is fairly low. DVD-RW cannot store true .jpeg digital still photo’s like DVD-RAM, however it is re-writable and has 80% compatibility with home DVD players.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Video Cameras Logo
169 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
