I have a 60in mitsubishi projection tv modle num vs-6047 made in 1996 the problem is that there is now picture the green light on the power button comes on the tv makes a click sound then the light goes off the tv doesnt even turn on.
  • squinty_420 Oct 07, 2008
    mitsubishi 60 in tv vs-6047 the screen does not turn on. the green light on the power button comes on, does not blink, then goes back off.
    mitsubishi 60in vs-6047 the screen does not turn on the power button comes on but then turns off
    Genius:
  • 1,011 Answers
Sir,
check autoshut timer is on if its on then off this function.
thanks
good luck
Posted on Oct 07, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, Your onboard circuit is faulty. You may want to consider getting a new TV instead of fixing it.
Fixing it might be expensive...
and Its not a good idea to try to fix it by your self as this model of Mitsubishi TV has lots of random problems reported by people.
reconsider getting a new TV.
  • 4,472 Answers
The TV will require professional service, based on your question it not advisable to attempt any repairs. I can assist you in finding a local repair shop or go to this link:
http://direct.where2getit.com/cwc/apps/w2gi.php?template=search_new&client=mitsuservicer#?mid=174138
There you will find an authorized service rep. nearest you. Please take a moment to accept and rate my solution as you should find this at least helpful. If you still need assistance please let me know before requesting more help.
Thanks,
Lee
  • 456 Answers
I can say the main problem is in power plug,
becoz the supply of power is disconnecting from te tv
so try to fix it
    Guru:
  • 1,894 Answers
And does that green light blink?
if so how many times?
  • 3 more comments
  • dewan nafees ahmed Oct 07, 2008
    does the picture comes ON for few seconds and then turns off?
    can you write the problem clearly using proper punctuations?
    the statements are unclear
    going into shut down means there may be couple reason bad voltage regulator no b+ relay bad or open solder joints
    The mitsubishi VZ5 chassis that will not power up often is the result
    of a leaky diode raising the voltage on IC700. A quick check is to
    check pin 4 of IC 700 for
    0 Volts DC. If pin 4 has any voltage replace Diode 980 on the main PCB
    it is leaky and the set should power up. This tip relates to all VZ5
    chassis mitsubishi's
    or it may be even a couple of bad condensers. If you take it to a local shop and total repair bill will be below $180.00
    there was no reply for the comments i gave you :)
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
