Question about Ovens
Blanco oven clock wont stop dinging. How do I turn it off. Turning the little dial off the alarm symbol it still ticks softly then reaches a point and dings again
4 Suggested Answers
  • 833 Answers
SOURCE: Alarm continusly dings and display is blank.
Spencer...I hope you did this with the power off! First, disconnect all connections and reconnect them. You may have forced a connector. Likely the board is blown...the display and microprocessor are closely connected.
Posted on Dec 07, 2007
kachbibi1
  • 979 Answers
SOURCE: oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
Posted on Jan 30, 2009
heatman101
  • 43501 Answers
SOURCE: Can't turn off ring on
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Posted on Nov 01, 2010
I'm after a blanco oven manual for BSO632. The
Blanco Oven
http://www.scribd.com/doc/7992811/Blanco-Oven
Sep 20, 2014 | Ovens
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
My Blanco oven will not work. Display shows 0:00 'auto' flashing. Cooktop works fine. I have checked the manual but it was of no help. Model number is BF95W. Tried turning off/on at power. This did...
Hi You need to set your clock If it is a digital timer you usually have to press 2 of the buttons on the bottom and once you see a change in the clock (usually it stops flashing) press the up or down button to set the time once the time is set you may need to push the manual button sometimes this button is identified by a hand regards Geoff Stove Recyclers WA
May 29, 2011 | Ovens
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
Belling synergie oven - main oven won't come on.
hi
check the timmer clock is not in auto mode as this will stop the oven from turning on. if clock ok then fault could poss be the thermostat
hope this helps you
regards dan
Mar 03, 2009 | Belling XOU174 Electric Single Oven
Zanussi lower oven not working
You should try to get a replacement dial first and go from there.
Oct 14, 2008 | Zanussi ZHQ575 Electric Double Oven
Child lock code -5- has appeared.
Here is what worked for me.
Turn left to light on, then off
on/off (light)
on/off
on/off
(4-5 times)
do not run through the complete cycle of options
just to the light and back off.
Ken
Aug 16, 2008 | Neff U1661 Double circotherm super...
F7 alarm
F7 stands for a faulty touch pad, faulty clock or both. Usually it's the touch pad. Most manufacturers recommend replacing both of the components. First, because they make more money that way, and second, it's the easiest (although more expensive) way to fix this problem. If you'd rather try and save some $$$, you can perform the following test and hopefully identify which of the two components needs to be replaced. The test... Disconnect the power to the oven before performing any repairs. Something triggers the clock to display F7 error code. You can unplug the touch pad from the clock and see if F7 comes back on. If it does, the clock is bad. If it does not, the touch pad is bad. Hope this helps, APP tech http://www.AppliancePartsPros.com
Aug 04, 2006 | DCS WOSD-230SS Stainless Steel Electric...
Ovens Logo
192 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
