Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
I bough a brand new Singer embroidery from America (I live in Australia). When it finally arrived I eagerly pluged it in using a regular plug adapter. It turned on for an instant and then quickly fizzled out. I had blown the machine, as Australia has a higher electricity voltage than U.S. Now I am unsure what to do next. Does anyone know if the fuse will have blown, or if it is the entire circuit board? Can fuses be changed easily? What kind of transistor / adaptor do I need to get to use this machine in Australia? Any guidance greatly appreciated!
  • preeyanz
    preeyanz Oct 25, 2012
    Hi, I have had the same problem. Could you please share your resolution to this matter. I have no idea what to do now. I bought this singer from the US and has no idea I was going to blow it up this way.
  • ayozzhero
    ayozzhero Jan 14, 2013
    Me too, it was a few minutes ago. I bought it from Amazon but I am in Malaysia with 240V.... did you blow yours?
  • 68 Answers
Unfortunately you need an 240AC to 110AC adapter for this kind of equipment (try **** Smith). A plug adapter does nothing to change voltage it just lets the plug fit the power point, this is ok for some smaller electronic devices that are built to automatically sense the voltage. There is usually a sticker in small print on the device that will tell you what voltages it will take. I can't tell you whether its been damaged, but by going by your description it doesn't sound good. You can try an AC to AC adapter but it may not work now. I'd ask the supplier for a replacement as they should have known that Aus is 240V.
Posted on Aug 30, 2009
Hi ive just retimed my machine but now the bobbin thread isnt been picked up x i have a singer HD 4423 xx
That is generally a timing issue. The needle is arriving at the bobbin at the wrong time to intercept the bobbin thread. Be sure you are using a brand new needle.
Feb 12, 2017 | Singer Sewing Machines
I can't get my bobbin thread to pull up.
Be sure to use a brand new needle and that it is the correct needle for your machine, that it is installed correctly (flat side facing the correct direction) and is pushed all the way up.
Check that the bobbin is loaded and threaded correctly in the bobbin case and there is at least 6" of thread tail.
If it still will not pick up the bobbin thread, then there is most likely a timing issue with your machine, ie the needle is arriving at the wrong time to intercept the bobbin thread. Take it for service.
Oct 18, 2016 | Singer Futura Xl-400 All-In-One Sewing And...
WHY does my SINGER 420 xl leave thread loops on the top of my design...I am so sick of this machine..Singer does NOT stand behind their products..I WILL NEVER BUY SINGER AGAIN!
You're probably correct. The new Singers are not what they used to be...Singer was bought out a few years ago and many buyers have registered their regrets and disappointment with the new products and service.
http://evadman.blogspot.com/2011/12/singer-xl-400-futura-sewing-embroidery.html
Most complaints about sewing machine problems concern thread loops under the fabric, which are usually caused by the upper thread. Your problem is not as common. Generally, when thread problems occur on the top of the fabric, it is a bobbin issue.
Try a brand new needle. Make sure the needle, thread, and fabric are compatible. Also, check that the needle is installed correctly.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjV3sKLxKvNAhUjE1IKHdbNDb4QFggkMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
All About Needles
Remove the thread from the machine. Check that the machine is clean--no lint, dust bunnies, thread pieces in the bobbin area, stuck in the feed dogs, or under the needleplate.
ALWAYS RAISE the presser foot when threading. Rethread the machine from the beginning. Check that the thread path is correct for the upper thread and that the bobbin case is loaded and threaded properly. Use the same thread for both upper and bobbin.
Most machine standard upper tension is set at the midway point. However, this is just a beginning point. The tension differs from one machine to another and may need adjusting depending on the fabric you are sewing.
Retest your machine.
If loops are still forming on the top of the fabric, then the bobbin tension may be too loose. Try tightening the bobbin tension (only 1/8th of a turn at a time!).
Understanding Thread Tension Threads
Sometimes it is a thread issue. Experiment with different brands of thread. Avoid old or bargain bin threads (the thread in bins at the fabric store are not the best, also Coats & Clark may not work well in your machine). Stick with better quality threads, ie Gutermann, Aurofil, Isocord, etc. Be sure to use the type of thread that is suitable for your project, ie do not use embroidery or cotton thread for sewing garment seams unless you want to be embarrassed when the seams start popping... Polyester used to be the bane of sewing projects but is now used for many items because the quality has improved and, in some cases, surpassed the former favorite cotton. Polyester is light weight but strong. Some machines just do better with one brand of thread over another.
You may also consider testing the machine with different types of fabric to see if it performs better with a particular fabric type or weight.
If it continues to be a problem, perhaps the bobbin case is damaged or malfunctioning. If you cannot find the answer to your problem, you may just need to take it for service.
http://jennys-sewing-studio.com/index.php/product-lines/singer-futura-quartet/75-singer-futura-quartet/155-faq-about-the-singer-futura-xl400.html
Jun 15, 2016 | Singer Sewing Machines
New machine, plug in turn on and it beeps at me and all the lights are blinking and it is doing nothing. It is a singer futura xl400
If it's new, take it back immediately! You'll end up with it in the shop more than your home. Go to a local sewing machine dealer with a repair shop. They can tell you which brands are reliable, and will fit your needs.
Feb 24, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
What needles do I need
As above, your machine will work fine with either standard sewing machine needles or embroidery needles from Schmetz, Organ, or Singer, but most experienced users find they use standard sewing machine needles instead of embroidery needles which are much more expensive. The only difference is on embroidery needles the eye is slightly larger.
Now, as to your snapping thread! The needle is not usually the cause of that. Your problem is being caused by too much tension being applied to the thread BEFORE it goes into the thread path, or it can also be caused by aged thread. Even if you purchased it new, it could have been standing on the shelf for a while. Most experienced users don't put the thread on the provided spindle; instead, put it in a mug placed at the back of the machine away from the embroidery hoop, and then thread normally. If you have a CE-200, you will have an auxiliary silver thread holder at the back you can use before the thread enters the normal thread path. Also, try switching the thread (as well as the thread brand) you are using to test if the problem is the thread.
Mar 10, 2014 | Singer CE-200 Quantum Futura Computerized...
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
I have a Singer Futura CE350 and I am trying to embroidery for the first time. I have watched the video and did the tutorial and have it all set up right. My needles keep breaking and my bobbin thread...
Make sure your machine is properly threaded. Use both hands when you thread it. First test your machine sewing regularly, if is fine it could be the tension. It has the tension preset but sometimes it requires for it to be loose or tighter. Also make sure your needles are properly installed. the flat part suppose to be facing away from you.
Are you filling your bobbins in embroidery mode? It helps a lot! Look for the steps online.
Jan 10, 2010 | Singer CE350
I'm new to embroidering. I have BrotherSE-270 Disney. I have read through the manuel several times and am confused about the bobbin thread. Do I use tread specficaly for embrodering or will regular thread...
Your machine probably came with brother embroidery bobbin thread (one spool, white)...I used it until it was gone and did buy more embroidery bobbin thread at a regular superstore (it wasn't brother brand though)...however, I have since used regular thread and not had problems. HOWEVER, be sure it is good, quality thread - none of that $.50/spool stuff. That knots up and simply doesn't look good if it does work. Good luck!
Jul 08, 2009 | Brother SE-270D Computerized Sewing...
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Using Hyperfont
hyperfont is a disc that you put into your pc which lets you use
the font (letters you type on your computer in windows true type)to be transfered to you'r embroidery machine and sewing on to
a garment, you can change the size make it Bold, Italic,Regular
The size depends on the size of your embroidery hoop.
Apr 19, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
312 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
