Question about ASUS P4SGX-MX Motherboard
No power i have asus p4ge-mx motherboard and its no power. but the led light green is lightning that is indicate that my power supply is working. but when i press the power button nothing happen no power at all. i tried new power supply the pull out the motherboard to the case still no power and i wondering that there is problem with my motherboard. how to fix that?. pls. help me
  • Anonymous Mar 01, 2009
    green led on board on none of fans run
    Scholar:
  • 69 Answers
Make sure you got the power switch plugged in the right front panel connector
make sure the ATX_12V is plugged in as well as the ATX
Posted on Oct 07, 2008
I need driver motherboard Asus P4GE-MX
download it from the asus site or just visit . www.driverguide.com
Apr 19, 2011 | ASUS P4GE-MX Motherboard
P4ge-mx motherboard no power
In this case simply #1 you want to make sure your power supply is good first.
Take a good known power supply and try it instead.
You don't have remove the motherboard, etc., just unplug the main ATX power connections and plug the good power supply in et al then see if it powers up.
It could be the power switch, but 99% of the time it's going to be either a bad power supply or maybe a bad motherboard.
Since it's a ASUS I doubt it had bad caps, but look on the mother board at the large capacitors and see if you you can find any obvious bad caps.
See: http://en.wikipedia.org/wiki/Capacitor_plague
Feb 17, 2011 | ASUS P4GE-MX Motherboard
My motherboard asus p4ge-mx has no power
the power led is not light..power supply is good..so the problem is the motherboard....how to repair that kind of trouble...
May 12, 2009 | ASUS P4GE-MX Motherboard
Need ASUS P4GE-MX Motherboard
Hi hithammaged,
please click on the link provided. This will open Asus web site for their P4GE-MX motherboard driver site.
http://support.asus.com/download/download.aspx?modelname=P4GE-MX&SLanguage=en-us
Suggest you book mark this site. Asus does not provide downloading the motherboard CD for free. How ever if you want the entire driver CD you can buy it from Asus E-store at this link.
http://estore.asus.com/shop/category.asp?catid=230
It's up to you.
Good Luck!
Mike
Jun 29, 2008 | ASUS P4GE-MX Motherboard
ASUS P4GE-MX Motherboard DIRVER DOWNLOARD
here is the link to the driver page:
Download.aspx?SLanguage=en-us
Enter
motherboard
Socket 478
P4GE-MX
for your drivers
Jun 24, 2008 | ASUS P4GE-MX Motherboard
Motherboard P4GE-MX, it broke cause there was thunder hit
This can be a number of things.. The first thing I would do is check all the cables and try a different outlet.. If that doesn't work, you probably need to buy a replacement power supply (can be returned if it doesnt work). If that doesn't work, the mobo is fried.
Mar 27, 2008 | ASUS P4GE-MX Motherboard
Asus P4GE-MX
If you have your manual you can see how to connect these on pg. 1-22. No manual..
Starting from the right edge of the board moving to your left. Notice there is two rows of pins one above the other. All your case connectors will be connected left to right & not up to down. The first two (BOTTOM ROW) pins are for the reset switch. The connector will have two wires one will be colored white or black. These colored wires are ground & will be the sane for all your connectors. All grounds will face towards the right for both rows of motherboard pins. After plugging in the reset connector SKIP one pin as you move to your left along the bottom row. Plug in your IDE LED connector a two wire connector. Moving to the top row across from the ide led, plug in the Power Led. It is a two wire connector. Some case connectors for the power led come in a three pin connector. If yours is like that than you will need to remove the + wire from the connector & slide it over one slot so it is next to the ground & plug it onto the board.
The last two pins is for the Power button. All Asus boards are marked & colored. You need a stronge flash light to see the markings on the board. Good luck!
Don't forget to vote..........
Jan 15, 2008 | ASUS P4GE-MX Motherboard
No Power
try to check 5volts on processor, south&north Bridge.if ever no 5volts supply replace Q7&Q7.. also check the bios.
Oct 25, 2007 | ASUS P4GE-MX Motherboard
ASUS P4SGX-MX Motherboard Logo
123 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
