Question about Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner
Temperture bulb heater temp display reads about 10 degrees higher than separate room thermometer.were is the best location of the temperature bulb?Also is a longer temp line available?
I called the tec support at rinnai.
Posted on Oct 07, 2008
    Scholar:
  • 121 Answers
A temp bulb will is only accurate to plus or minus 10 degrees sometimes as much a 20 degrees the ideal place for the bulb is in the intake air flow the bulb comes with a line that is long enough for this application
My thermostat showing on screen 76F when really room temperature is 70F and I HAVE MEASURED PROPER room sensor resistance OHMS to real room temperature. Why thermostat showing higher temperature and n
Where is the thermostat in relation to the return? Is there air flow or is the air stagnant in the area of the thermostat. Have you placed a thermometer in varios locations where the thermostat is located? Try these locations and see if the thermostat needs to be placed in a location better able to reflect room temperature. Also how long have you lived in the house? If it is a newer home I suggest that you contact the builder or the air conditioner/heater installer to see if they have a schematic of the placement of the thermostats.
Nov 25, 2014 | Honeywell TH8110U1003 VisionPRO 1H/1C...
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
My refregirator temperature sometimes warms up 10 to 15 degrees higher when i open its doors to load it up with items and takes a long time to cool back down.
If your reading the display temp , your reading what the thermistors are telling the control board . NOT the actual temp inside . After closing the door , from the food that was already cold in the fridge , the coldness will keep the inside temp , the same temp as when you opened the door . The thermistors themselves will detect the warmness and send it to the board . A good way to try to put this acrsoo , is to put a thermometer between , say , 2 packages of salads . Wait a little while and open the door . Watch the display temp , then read the thermometer between the packages . The thermometer will stay the same , due to the coldness of the packages not changing . When you put food in the ref , the surrounding food will give off some of the coldness to the freshly installed food , thereby makeing it cold faster . After a while , this coldness will return to the thermistors and the display will start to drop in temp . Hard for me to put into words , except for , the temp reading will actaully be the same as the actual temp display , only when you FIRST open the door .
Sep 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Rinnai 1004 heats to a temp 4 degrees higher than set temp, adjustment?
You can adjust the position of the room air sensor found on the back of the unit between the heater and the wall. It is a black rubber bulb with yellow wires. There is a few inches of extra wire you can extend higher to get a more accurate reading of room air. While you are back there, check for drafts that will give you false readings.
Sep 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner Logo
94 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
blender719
Level 1 Expert
Dan Webster
Dan Webster
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
