Question about Garmin GPSMAP 60CS GPS Receiver
Loose USB connector
I was able to download maps using USB before but now my connector is loose and the computer will no longer mount the Garmin as a USB device. It seems like a hardware problem. Is that something worth trying to get fixed ? Please advise and thanks in advance.
  • gadgetlvr Oct 28, 2013
    These guys are really good at fixing a loose USB and their prices are reasonable. Check them out
USB connectors are too fragile for the constant in-out service they get. But I have solved the problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
Posted on Feb 17, 2011
Garmin nuvi 1490 will not connect to computer or vehicle, do you think it is the battery
Sounds like either the battery is completely dead, although there should be some hardware/software response from a usb connection.
The other possibility is that the USB port on the GPS is no longer connected properly internally. Does the Plug feel loose when you plug it in.
General problems could be that you need specific drivers before your operating system will connect to it or provide a charge.
Then there's always the chance that the cable your using to connect has a short or can't connect because of physical damage internally or to the USB end of the connector.
Aug 31, 2013 | Garmin GPS
I have old garmin nuvi sat nav and when I use car charger it goes in to charging mode and would not display any map
Broken/loose USB jack is the cause of the problem. Seen it many times. The connector either needs to be replaced or resoldered. More info can be found here:
Apr 18, 2013 | Garmin nuvi GPS
Charging connector is loose
Yes, you have found the problem. The mini-USB jack is broken, preventing the battery from being charged. However, you can charge the battery by using the 660's snap in cradle and bypass the USB port. If you want the jack replaced, please see this link:
You will want to fix the jack because you will not be able to update the firmware or map until the jack is fixed.
- Jim
Dec 05, 2011 | Garmin Nuvi 660 GPS Receiver
How instal maps on sd memori card for garmin nuvi 250
Insert the memory card into the memory card slot on Garmin Nuvi 250 GPS device. The memory card slot is located on the left side of the device. Push the card in until it clicks. (If you inserted a memory card that already has pre-installed maps and files, there is no further action required. The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable. The mini-USB connector will need to be inserted into the rear of the Nuvi 250; the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX formatted Waypoints and other mapping-related files. Right-click on it. Select "Copy."
Select the "Computer" folder from the computer's desktop Start menu. Double-click on the "Removable Disk" drive that represents the Garmin Nuvi.
Right-click in an empty space within the drive and select "Paste." The files have now downloaded to the memory card and will be accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
Dec 06, 2010 | Garmin nuvi 250 GPS Receiver
How can I register & get map update?
with the unit off
plug in your gps into the computer using the usb connector cable ( most are the same usb cables cameras use to connect to your computer)
once connected your computer will find the new hardware
now go to
Register your unit there and it will let you unlock your maps
It will tell you to download WebUpDater utility to transfer maps
The Garmins have a SECURITY LOCATION feature in them, just in case its stolen or lost.....
the only way to unlock your Nuvi when you lock it with your Pin Number is to go back to your Security Location......your Security Location will be where you Setup your GPS at.. could be work or Home just remember where... if locked you would have to go with-in 50 meters of Security Location to unlock or send your unit back to Garmin with proper receipt of ownership
Nov 03, 2010 | Garmin Nuvi 1490T Kit 5 In UltraThin GPS...
I have a Garmin nuvi760 GPS it no longer gives me any directions it does show me a map.It did have a comment that it has to be upgraded. What am I suppose to do. The GPS is registered my serial #...
Try a Firmware update...
with the unit off
Plug in your gps into your computer using the USB connector cable
it will detect new usb hardware
now go to
it will also detect your gps and let you update the Firmware
Nov 02, 2010 | Garmin GPS
Where do i find seriual number? how do i register my gps ? and how do i downdload 2011 maps?
depends on your unit... The Nuvi serial number is on the bottom of unit where it connects to the cradle to mount, Garmin also puts a number sticker on the Box your Nuvi came in.
you must first Register your unit to update and unlock your maps with Garmin
with the unit off
Plug in your GPS to your computer using the USB connector cable.... your computer will detect new hardware
now go to and Register your unit get updates for maps and Firmware there,
Garmin will detect your unit and let you download WebUpDater utility to transfer maps
Nov 01, 2010 | GPS
Garmin NUVI 200W USB Port port pulled loose
The problem with repairing it yourself is that this is a surface mount connector. The solder pads are so small, it would be very difficult to solder with a standard soldering iron. Most likely you would apply too much solder and short out the connector. You really need to use a surface mount soldering/desoldering device and that can be fairly expensive. I have done this before but I have access to the right equipment.
Also, there is a possiblility that the printed circuit board tracks have been pulled up off the main board. If that has happened, there's a lot more work involved in fixing that. You might have to put in a different type of power jack and run wires from it to the main board.
If you're going to try to salvage the USB connector, I would remove it completely and install a new one. Over time, these connectors wear out, so you're better off removing the old one and putting a new one in. Again, this all depends upon whether the tracks on the board have been damaged or not.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
You also have to know how to take apart the Nuvi.
Jul 20, 2008 | GPS
Garmin GPSMAP 60CS GPS Receiver Logo
531 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
