My usbest usb2.0 flash drive is no longer working. the computer does not recognize the drive
  • Anonymous Oct 20, 2008
    my tiny disk is not functioning anymore.. i dont know why.. my tiny disk is veritech USB2.0 128MB.. pls help...
  • Anonymous Nov 02, 2008
    My pendrive is reconocize but not open, is Markvision 2 Gb
Ok, so I just searched Google for about 5 hours trying to figure out how to fix the USBest USB2flashStorage USB problem. What happened is the part of the memory that tells the computer how to access the drive and how big the drive is got corrupted. You need a program called "Super Stick Recovery Tool" made by kingmax. Don't worry that your drive isn't a kingmax drive, it will work anyway because it is just going to completely write over that little part of the drive that got corrupted. just go to "http://www.kingmax.com/en_04_download.asp?usn=2" and download
Super Stick Recovery Tool V1.0.2.19.rar
you can open the rar file with winrar or 7-zip. Inside is
Super Stick Recovery Tool V1.0.2.19.exe. Run it as administrator with the drive plugged in and click "Update"
about 5 minutes later-- Problem solved!
*Warning* This erases everything on the drive, I have no clue how to get data off of it before you do this, but at least you can have a working jump drive rather than a paper weight.
Just so you know, I only tested this on a Verbatim 8 Gb drive that had the exact same problems you described. I tried lots of other tools and they didn't work. Super Stick Recovery Tool Rocks!
Posted on Jan 03, 2010
  • 1 more comment
  • blind_1 Nov 29, 2010
    This solution is still the best 11 months later!! Thank you sulldog101 for this post!
  • Dirty Ho Dec 10, 2010
    12/10/2010: This program is the absolute Best!!! I am a tinkerer with freeware and components and I used my Thumb Drive religiously. I did not want to give in and chuck the Drive. SullyDog...you are the best! New version of the program is even better. I got my drive back and will attempt to recover what I can in personal files. Completely satisfied. Highly recommended!!!!!
  • bernard louis Jan 29, 2011
    Merci sullydog101 pour ton info qui vient de me dépanner ma clé USB EMTEC de 16 Go.
    J'avais le problème depuis 2 ans et je croyais que cela venais de mon tuner tnt qui ne pouvait pas enregistrer au-delà d'1h30. En fait ma clé USB était limité à 3,5 Go, mais je ne le voyais pas.
    Par contre ton logiciel n'a pas fonctionné pour moi. Soit cela vient de la clé soit de mon OS (Seven).
    mais j'ai trouvé sur le site que tu donnes un autre utilitaire qui m'a dépanné dans les mêmes conditions d'utilisation que tu donnes.
    Pour info, il s'agit de "UFD_Recovery tool V1.0.1.0"
    J'écris en Français car je suis de l'Aveyron en France, mais les traducteurs sur internet ont supprimé la barrière des langues.
    A et merci encore
Hey, if anyone is having a problem with the usbest usb2 flash storage pens, try my solution! I was having the problem - computer recognizes, but when selected says 'please insert disc into drive d'.after searching the net, with no luck, I decided to open it up (its really easy, just unclips). Then I just moved the silver cylindrical thing a few times. I then inserted the usb and the L.E.D flashed once, good sign! The icon on bottom right of screen said unknown device, not installed properly.which was unusual. I then took the pen out, and put it in slowly, just untill the light came on.after the pc installed it, I could insert it all the way, and its been working fine ever since!hope this helps someone! d
Posted on Apr 05, 2009
Awesome tip sullydog101 !!!... It really worked. Now i can use my pen drive again which i thought became useless. Only thing was that i lost all my data, but fortunately i had it all backed up :). Thanks a lot
Posted on Jan 07, 2010
  • 6,487 Answers
Try to connect the USB flash drive on a different USB por on your computer and if possible try to connect the flash drive on a different computer and if still not detected on different computer the falsh drive is already defective and needs a replacement already.....
Hope that helps................
Posted on Oct 07, 2008
It works on my PNY 4GB USD flash drive....awesome !!
Posted on Jun 02, 2012
    Genius:
  • 1,179 Answers
This company has changed the file ,it is now located here ( http://www.kingmax.com/en_04_download.asp?usn=1 ) and is called UFD_Recovery tool V1.0.1.2 "UFD_Recovery tool V1.0.1.2.rar"
Posted on Apr 14, 2011
How to rewmove write protected
If you have garantee from manufacture, use it. If not... you can find program for format you flash drive, but you need to know your manufacture and chipset on your flash drive. for example. I have MyFlash from A-Data, chipset/controller is USBest UT161-T6G. I found a program to unlock my flash drive. Good luck to you!
Aug 18, 2011 | Electronics - Others
Usb stick not usable
Because its beyond 4Gb that's why its already detected as a disk drive.
You can still save your files here. Have you already tried?
If so, what is the exact error you are getting?
Aug 06, 2009 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Computer no longer recognizes sandisk when inserted into USB port
Dear, it is out of order thats why there is problem, don't attach it otherwise it will cause more problems, it gets hot due to the circuit shot. So, visit the repair shop for better solution.
Best regards.
May 27, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My Windows XP is no longer recognizing my cruzer 8gb
With the flash drive plugged into your computer, go to start>settings>control panel>administrative tools>computer management>disk management
Your flash drive should be there. Right click it and select "change drive letter and paths." Click on "change." Change the drive letter.
Just follow the directions to finish.
Sometimes, if you turn the computer on, insert the flash drive, and reboot, the drive will show up, it is detected on start along with your other drives.
(I recommend starting at the end of the alphabet (Z) and work backwards when selecting the drive letters for flash drives, that way, in the future it will be easier to recognize them.)
Jan 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Usb flash drive not recognized when plugged into hub
data is lost,
test with H2testW'
fix with PD V1.08 B3
good luck !
Jan 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flash Drive driver
I had same problem with my computer...i tried usb flash card all in one and it worked for me...hope that helps...
Aug 24, 2008 | Computers & Internet
Pleomax 6gb USB Drive No Longer Recognized by My Computers
It's either the USB port, the drive electronics itself, or the USB cable.
First I'd try a different USB cable.
Apr 06, 2008 | Computers & Internet
Problem with sandisk 2GB Micro USB Flash Drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Let me know what happens.
cynthia
Jan 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
7,578 people viewed this question
David Payne
David Payne
