Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
E21 error code
Will not record to disc.
My washing machine has a code e21 what do that mean
Please read description carefully about error code
Logik Washing Machine Error 21: "E21"
Error Code Definition: Washer has not drained in allotted / time washer not draining.
How To Clear Error Code:
-Check that filter is not blocked or kinked
-Check drain hose is clear of any blockage or kinked
-Check wires to drain pump
-Check drain pump is not faulty
-Check level sensor and switch
-Check wires to level sensor
here is link for more about your all error code which will may helpful in future, LOGIK Washing Machine Error Codes How To Clear
here is video which helpful regarding solve and understanding error.
Mar 16, 2017 | Washing Machines
I have a Bosch dishwasher that had error code E24. DW would work if door was opened about 1 minute into washing. New drain pump. No fix. New error code of E21. New control unit, still same problem.
E21 is a circ pump blockage issue. Check that all hoses are clear, unit drains completely. Depending on the age, a new circulating pump may be needed or new motor capacitor.
Jun 22, 2016 | Bosch Dishwashers
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
What does error code mean e21
Manual says E21 is 'Off Line'. Not much to go on there but I am guessing that is probably referring to something that is plugged into the serial ports on the side - perhaps it is looking for an external kitchen printer of something along those lines.
Jul 09, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
Treadmill not working. Troubleshooting: Receiving E21 message. What does E21 indicate?
The E21 error code indicates that the console is not receiving a signal from the sensor that controls the speed on the treadmill. This means there could be a problem with the speed sensor. You may need to have a technician check the voltages on the power board and controller.
Nov 27, 2010 | HEALTHRIDER Exercise & Fitness
Error code E4 54040990, and E21
use dvd-r they are not as tempermental. plus they are more universal if giving the media to somebody that may be older.
Jun 02, 2009 | Radio Shack Accurian ADR-0106
Canon DR-5020 Error Code E21
Just saw your problem! 'E21' refers to Document Board Motor Problem' Check if there is any loose contact and if required replace motor.
S. Mohan, Chennai, India
Jan 08, 2009 | Office Equipment & Supplies
Error code E21
you need a phillps screwdriver remove the top . control panel then the front... hope it helps
Aug 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
169 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
