Question about Pinnacle Studio Version 9 for PC
Creating a Movie
Every time I try to Create a Movie file for Tape Output, just when it is almost finished the system crashes and Pinnacle closes. Some application error pops up.
    Sergeant:
    Champion:
  • 334 Answers
Try differnt program or pc getting to hot over heat from powerfull decoding then restarts it self could be heat cpu not good enf do all windows updates also
Posted on Oct 07, 2008
  • nick helpap
    nick helpap Oct 07, 2008
    dl and patches software makers may have at websiet for yours also
Pinnacle studio ultimate 12
Does the player you are using for playback support the file format you saved it in? If not you will need a codec to view it.
Sep 02, 2014 | Pinnacle Studio Version 12 for PC
Tip
How to convert MVI to AVI file for edit in Pinnacle Studio?
Some Canon digital still cameras (Powershot A75, A63, S410 etc), are capable of shooting a limited amount of video, since there is no tape, it is saved as an MVI file format. However, the MVI file format is not compatible with other programs. Even windows media player refuse to play MVI file. Besides, editing software like Pinnacle Studio and Windows movie maker do not work with the format. Because of this, the files need to be converted to a format that is more widely used, such as AVI so that these videos shot with still camera can be played and edited as easily as other common videos. This guide is to tell how to do that.
Software you'll Need: Pavtube Video Converter
Step 1. Download Pavtube Video Converter, and follow the prompts to install the program. Click "Finish" when the installation is complete, and Pavtube Video Converter will launch automatically.
Step 2. Click “Add” to load MVI files or directly drag the files into file list. By default, the files are selected. If you would like to join all the selected files together, check the box of Merge into one. You could view the files in preview window, simply highlight the file and click play button.
Step 3. Click “Format” bar to determine output format. Follow Common Video-> AVI Video (*.avi)/ DivX AVI(*.avi). Click “Settings” if you’d like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels. Do not forget to click “OK” to confirm your settings. Then type in a desired output location in the "Output" box.
Step 4. Click "Convert” to start converting MVI files to AVI. You could set auto shutdown in progress window or leave it there and come back later. After conversion you could edit the converted video in Pinnacle Studio, and make a film out of it or burn it onto DVD.
Learn more: http://www.pavtube.com/guide/convert-mvi-to-avi-for-edit-in-pinnacle-studio.html
on Mar 25, 2010 | Cameras
Export:error:real time c:\users\owner\appdata\local\microsfolder\render\my movie 848e009f\alternate\render\my movie 848e009f\dvd\studiosequence\temp' Help - what does this mean? What should I do?
Hi and Welcome,
If you are experiencing Export Errors using Studio, the following FAQ should help:
1. UPDATE TO THE LATEST PATCH:
Click here for the latest Studio 12 patch
There is no patch available at this time for Studio 14
2. ENSURE BACKGROUND RENDERING COMPLETES:
Allow the green bars that appear over clips that have had filters, transitions or other effects added to complete before going to the Make Movie stage.
3. ALWAYS REINCODE ENTIRE MOVIE
If after installing the latest version of Studio, the Export Error persists and you are attempting to create a DVD, then in Studio click on the Setup pull-down menu and select Make Disc. On the top portion of the Make Disc tab make sure there is a check in the box for the setting "Always re-encode entire movie", then click the OK button. Create the DVD again.
4. DELETE AUXILIARY FILES
Delete the auxiliary files before rendering. To do this, go to File >> Delete Auxiliary Files. This will bring up a window to chose which auxiliary files will be deleted. Select the option to delete the files for the current project. Once this is done, try to output the project.
Oct 12, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle 14 crashes at the same point when making movie.
Hi
My pinacle 14 crashes when I try to make a disc, if I make a disc from other movies i have edited it works just the current project we are working on , I have deleted the Aux files
Cant move
Peter
Apr 28, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
When making / creating a DVD, how do you make the "Play" button work, so that the result of your movie you will select the "Play" button and your movie will play. Also how do you create chapters, but allow...
hi there,
you can find the manual here :
Pinnacle Pinnacle Studio Ultimate Version 11
and in other languages please look here :
ftp://ftp.pinnaclesys.de/Manual/Studio%2011/
I suggest to look under the word :
Scene detection ...............26
The Video Scenes section ....... 40
CHAPTER 9: DISC MENUS.... 175
Output to disc media ... 243
Have a nice computing
Hope that helps
IF NOT then try to return here
Please rate my answer
Dec 09, 2009 | Pinnacle Studio Ultimate Version 11
Unable to get dv input / output via ieee 1394 port
try an older version of pinnacle studio or another pc if still no capture, firewire camera board failed.
Oct 24, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
File/Folder Permission Message in Pinnacle Studio 11 Plus
Hello welcome to FIxya!
Here you can check this procedure on how to open your files again.
"1) Check your Recycle Bin
2) Do a Folder/File Search for each of the Grey Folder Project names. This will display all Folders & Files with that Project Name. You are looking for an .stx File. If it's there, right-Click on Project Name / Open Containing Folder & Copy it to your My Projects Folder. Then you should have both the Grey Folder & .stx File for the same Project name, showing in your My Projects Folder.
If the Search doesn't display a .stx File, you can create a new one, by Opening a New empty Project, which will create a My Movie Grey Folder & a My Movie .stx File, Save to your My Projects Folder. Delete the My Movie Grey Folder & Rename the My Movie .stx File to the same name as your original Grey Folder."
So ...after finding my "lost" movie file, with its file name, under Documents\Pinnacle Studio\My Projects i then went through the following procedures using your great advice Colour;
  1. Make a copy of your found "lost" movie grey film icon file by right mouse clicking on your lost file and choosing "copy". Paste the copy into another folder in Documents where you can find it if need be
  2. Then go back to Documents\Pinnacle Studio\My Projects and right mouse click onto your grey film icon. Choose "rename". Then rename your "lost" grey film icon to a new file name but do not put .stc at the end of the file name, if you are operating VISTA and Pinnacle 12. This is important because Pinnacle 12 won't recognise the file later if you have .stc in the file name
  3. Open Pinnacle and go to the File Menu
  4. Click on New Project
  5. Open File Menu again and click on Save File as
  6. Give the file a name such as "Movie 7" and save it
  7. Close out of Pinnacle
  8. Open up Documents\Pinnacle Studio\My Projects and observe that you now have 2 new files there ...a grey film icon file saying Movie 7 AND a coloured Pinnacle icon file saying Movie 7
  9. Delete the grey icon file with the file name Movie 7
  10. Now give your coloured Pinnacle icon file the exact same rename as your precious "lost" renamed grey movie icon file, using the right mouse click on rename proceedure as explained in No.2 above.
  11. Close out of Documents file
  12. Now open up Pinnacle again
  13. Go to Menu and choose Open Project
  14. There you will see the coloured Pinnacle icon file with the new name of your "lost" movie file.
  15. Click onto its coloured Pinnacle icon, and watch your "lost" movie come into view again
Nov 16, 2008 | Pinnacle Studio Plus Version 11
Pinnacle Studio 7 - Can't create MPEG file?!
Your output is set for tape. You have to change it to another device if your not sending to VCR. If you record to VCR, the Svideo or composite output to your video card is used while the audio goes through your sound card. Those cable ends are attached to a VCR. You can do the same with a DVD recorder if you have one. If your sending to to a DV tape, version 7 doesn't support it. Version 9 and higher do.
You Tube uses Windows Media files. Save the files in that format.
Jul 28, 2008 | Pinnacle Studio Version 9 for PC
Pinnacle Studio Version 9 for PC Logo
101 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
