Question about ASUS A8N-SLI Motherboard
Can You Put Windows On A 1TB internal Hard drive
I have (2) IDE hard drive on my A8N-SLI Deluxe M.B now How do I hook up my 1TB sata to my computer, Do I have to have two sata HD's for it to work I'am keeping my to IDE HD's in the computer
  • billyd48160 Oct 07, 2008
    That Answere part of my Question Thanks, But can I put windows on my new 1TB hard drive and use it like any other drive? I have a A8N-SLI Deluxe Mother
    Genius:
  • 1,124 Answers
If your motherboard has both connections you can have both (IDE and SATA) working together
Depends of your motherboard features.
Posted on Oct 07, 2008
Hi I have a A8N-SLI motherboard running XP when first switch on it stops at xp splash screen. when switched off and rebooted i am able to go into safe mode even when i noticed that before going to windows...
Windows Xp especially six years ago never had good native sata support. You need to load sata drivers for it to recognize the sata drive.
You need to got to Asus's website and download XP sata drivers for your motherboard. You can try to install them with the sata drive only connected in safe mode and if not with a floppy(if you still use them). Also make sure that you are connecting the sata drive to the correct sata port on the motherboard usually sata 0 or 1.
May 09, 2011 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
If I bought a SATA dvd drive, where would I connect it to? Does it take SATA dvd, or does it still need to use IDE only?
This MoBo has 4 SATA connectors. Assuming you have one or two hard drives just plug it into one of the spare ports. If you are unsure, carefully follow the data cable from a hard drive to the MoBo to find the ports.
Nov 28, 2009 | ASUS A8N-SLI Premium Motherboard
"A8n32-sli deluxe" SATA support disapeared
call or visit ASUS support forums, you may need to RMA this board.
Aug 09, 2009 | AMD ASUS A8N32-SLI Deluxe Socket 939...
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
IDE Hard Drive
What ur sayin is ,,the windows xp thats on the hdd ,,was put on the hdd while in another cpu,, now its in that computer,, if thats the case,a lot of times when thats done,, its tryin to load the other cpu,, in other words ,, its sein things are diffrent ,, causing problems ,,ur best bet is 2 reboot ,,load ur windows disk and fresh copy on that hdd,, ,,,,hope that was helpful,, thanks
Oct 05, 2008 | ASUS A8N-SLI Deluxe Motherboard
Where to start
Disconnect the Maxtor drive completely. Play a game or what every & see if the system runs ok. Personnally you should be running a SATA as C:\ since it will transfer much faster than an IDE. Give it a try & post you're findings.
Mike
Jul 13, 2008 | ASUS A8N-SLI Deluxe Motherboard
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
Asus A8n-sli premium with amd 64 3700+ proc
Usally blue screen errors are from ram. Do you have the right ram for that board?. Is the ram set to the right speed in bios?.
Feb 28, 2008 | ASUS A8N-SLI Premium Motherboard
ASUS A8N-SLI Motherboard Logo
214 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
