Question about Watches
Holes in gold crown. Can the crown it self be repaired and recemented in place?
    Scholar:
  • 48 Answers
Yes, watch crowns are replaceable but this is not necessarily a do-it-yourself job.
My father is a semi-retired watchmaker (54 years in business) and all to often receives a watch in numerous pieces and is asked to reassemble after an attempted self repair.
As well, the holes (pitting) are normal with age, as our sweat corrodes the metal over time, but especially gold.
To understand how the crown is attached, see the following site:
http://www.cwrnh.com/techpages/crownstyles.htmn crown
If you wish to try it yourself, these directions are pretty good, but work slowly, as this is very fine work, and 'close enough' does not work, and most people do not have the fine tools that are required and use oversized (for this job) tools that do not really fit...increasing potential for greater damage.
Do it yourself directions:
http://www.cwrnh.com/techpages/fitting_stems.htm
Since you will need to obtain a new crown from a watchmaker anyway...perhaps ask for the installed cost...especially if this is a gold watch...it might be worth it...it is not an expensive repair.
Hope this helps you to make an informed choice.
thanks
Posted on Oct 08, 2008
98b104 crown broken
best to go to a bulova dealer to get the original fitted as its most likely the stem is sheered of inside the old crown if however it has just unscrewed from the stem any good watchmaker should be able to refit it and reseal it
May 08, 2014 | Bulova 98B104 Mens Watch Gold Tone...
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
I want to remove my quartz movement to dry moisture from inside my watch. How can I remove crown, so that I can remove movement? Watch is old Gruen. Not worth shop repair.
Thanks for contacting FixYa.
It is WAY too risky to remove crown/fixture. Try this instead;
  • Step 2 Lay the watch in a dry place in sunlight and see if the water evaporates on its own. Put a piece of soft, absorbent cloth such as a towel under the watch. If the water inside the watch face is only a fine film of condensation that clears on its own after a short time, you probably do not need to do anything else.
  • Step 3 Seal the watch in a plastic bag filled with unopened packets of silica gel desiccant. These are the packets that come in shoe boxes and other packaged items. You can also use dry rice instead of the silica gel packets. Leave the bag somewhere warm and dry for a few days. The silica gel packets or rice can help draw out the water from inside the watch.
  • Step 4 Direct a fan at the watch or use a hair dryer on the lowest heat setting to blow air on the watch. Alternatively, if you can safely leave the watch on top of a low heat source such as a floor vent or radiator, this can help evaporate the water from inside the watch.
  • Step 5 Obtain the appropriate watch repair supplies. If you need to purchase tools, look for these at a watch repair shop or at a jewelry store. You can also find watch repair tools online. You may need small, fine-tipped screwdrivers and watch openers and closers.
  • Step 6 Take off the back of the watch, as if you were changing the battery. Use care not to scratch or damage any of the mechanisms such as the coil or stem. Let the watch dry thoroughly in the open air until there is no trace of moisture. Reassemble the watch once it is dry and press the seal firmly back into place. If the seal does not fit tightly, you may need to replace it
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Best regards. Jewel
    Sep 21, 2010 | Watches
    Can set date; cannot set time?
    If the crown turns in the setting position for the day/date and nothing happens then there is damage to the setting mechanism and this will need to be repaired by a qualified watchmaker.
    Hope this helps,
    Ken
    www.yellowstonewatch.com
    Apr 12, 2010 | Chase-Durer Wing Commander XVl Chronograph...
    My men's presidential date just is very difficult to wind. I try to wear it often, but it quits. The winding mechanism is so stiff that I can only partially wind it. It does move easily in the oposite...
    If it has only recently gone stiff then it sound like a trip to the dealer for repair.
    It may sound daft but all the Rolex I have examined are self winders. Is yours? (you can often hear the self winding mechanism by placing the watch close to your ear and rocking it gently).
    Could it be that you need to pull out the crown to wind it?
    Feb 03, 2010 | Rolex Mens Super President, 18kt YG
    My watch is not moving . I want to know do I need to change the battery or it is self wind? ref. 384858.Thanks
    Its easy to tell if its battery operated or self wind. Turn the crown (where you set the time) forward. Self wind watches will click as you turn the crown. If its battery operated then you will hear no clicks. Some watches have a screw down crown so if the crown wont turn forward then try turning back. Some watches have a capacitor that needs to be charged! Seiko Kinetics are charged by movement like an older automatic. Citizens are charged by light!
    Jan 09, 2010 | Piaget Watches
    Screw down crown wont lock
    There are only two things that can cause screw down crown to malfunction. First is dirt and second is weakened/damaged thread. In first case you need to use ultrasonic cleaner by immersing the crown AND case to get rid of any dirt and grime sticking on both threads. If the matter is weakened/damaged thread - you will have to fit new crown and (possibly) new case tube on which crown is screwed onto. This can be done by decent watchmaker only.
    Rate me, plz.
    Jan 06, 2010 | Watches
    RELACED WATCH BATTERY BUT WATCH STILL STOPS
    The best place to take is a jewelery store or some place that can repair watches/replace batteries that has a cyclonic quartz watch tester b2164de.jpg A cyclonic can detect if there is a pulse (the electrical signal that makes the hands move) even if the hands don't move. It can also spin the gears/hands to unstick the gears if some debris is holding them up. If there is no signal the coil or something inside the watch may have been nicked or something else is wrong with the watch and may have to go to a watchmaker/repairer or replaced.
    Oct 23, 2009 | Watches
    Ebel Classic Wave fitting a new crown
    i have changed the battery on my and my wifes ebel classic wave watch,,
    step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
    step 2 ...remove all 5 gold bezel screws
    step 3... be careful,, the bezel/crystal will pry off easy
    step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
    step 5.. small screwdriver and remove/replace battery
    step 6... reinstall watch guts/bezel and gold screws
    step 7... push crown back into watch
    step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
    if have done it many times ,, you can do it !!!!
    Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
    Watches Logo
    341 people viewed this question
    Top Watches Experts
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
