Question about Whirlpool Washing Machines
Whirlpool awm 8121 7 kg front loader worn drum pully req sapre part. PN 481252858041
SOURCE: whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Posted on Aug 17, 2008
capsman
  • 111 Answers
SOURCE: not finnishing cycle AWM 8121
Can you manually advance it through all the steps of the cycle? If so, you can live with it until you replace the little timer motor. (I once carved a tiny wooden gear to replace a tiny nylon gear on the timer, and that worked fine for another 20 years.) If not, then I'd say the control unit needs replacing.
Posted on Nov 11, 2008
  • 4 Answers
SOURCE: Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Posted on Dec 15, 2008
  • 3 Answers
SOURCE: I have a whirlpool front
Probably needs a new "mother board." I've had to replace mine 3 times. It's expensive too.
Posted on Dec 28, 2008
  • 119 Answers
SOURCE: How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Posted on Apr 26, 2010
Whirlpool awm 8121 leak
down by the water solenoid those leak sometimes or a loose hose if you cant fid it it might also be the seal in the drum
Aug 25, 2014 | Washing Machines
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water from a whirlpool AWM - 293 front loader
I too have this model machine. The leak in my case traced to the fill up hose that attaches to the drum. The seal at this point seems to be a weak point and requires either a replacement that will only last another couple of years or you could try what I did.
I removed the rubber hose from the drum. Dried and cleaned it thoroughly. placed a fair bit of sealant (silcone) on both parts and reassembled and let sit for a couple of days till it cured. This will need to be redone in about 3 years (that is my average- have owned it for 10years).
Jul 26, 2009 | Whirlpool Washing Machines
Front loader whirlpool washing machine won't go thru cycles.
"o" is an unsual code. usually it will have an "f" then a number. it may be that you are having a draining issue. is the unit full or have some water left in it? if so take off the front panel and see if you can remove the sump cover. be ready for water to come out, then remove whatever is blocking the pump and sump area. it most liekly has lint or items in there causing no drain.
Dec 28, 2008 | Washing Machines
if poor filling-
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool 6th sense front loader awm 8121
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal De
