Problem with gateway notebook ml6720 while starting .it is not showing any display .there is only flickering on screen
  • 39 Answers
There should be a button on your laptop that has a holow and filled screen on it hold down the function key and hit that button it will switch from the external monitor to the built in monitor
Posted on Oct 07, 2008
Can the gateway ml6720 realtek lan driver be used with the Ml6721?
Probably yes, I would go directly to the Realtek site and download it direct from the source. Use the newest driver.
Jun 04, 2014 | Gateway ML6720 ML6721 ML6725 Keyboard...
My laptop Gateway ml6720 has a black screen Ive replaced the battery and power adapter no change. The fan comes on and it sounds like it boots up but no screen.
Sounds like either the screen or the video adapter has gone bad.
Do this: Connect the computer to an external monitor (there is a SVGA plug on the side of the computer. Be sure when you turn it on that you press teh Fn-special function key combo that switches the video output to the external monitor. If the external monitor works, then it's your computer's screen. Possibly the inverter. If the external monitor shows nothing, then it's the video card (which may be built into your motherboard).
Oct 05, 2011 | Gateway Computers & Internet
I have a gateway ML6720: gets into BIOS OK, but won't BOOT
Upon starting up your computer keep pressing the F8 key. You will see the repair screen come up. Choose the line where you can use the c:/ prompt so you can do the following
When the black DOS screen appears type in chkdsk /f /r
answer Y and reboot
The computer will run a check and repair on your DOS system
When done in a hour or less reboot and see if it will operate correctly.
It is best to have a system reboot disc handy if this happens again. I would create one on a CD if this fixes your problem
Jul 27, 2010 | Gateway Computers & Internet
Gateway cx210x notebook: screen flicering and becoming pinkish
hi there, it may be that your cable connecting your monitor to the computer is being wiggled loose. You need to leave this to the pros as this can't be explained over the internet. You need to bring it to a computer shop for them to reconnect the computer. Tell them that the monitor cable is being severed from the graphics card.
Jan 31, 2010 | Gateway CX210X Notebook
My Toshiba p105-s6064 display screen is only showing half of my desktop, the other half goes black or flickers various colors. Do I need to replace the display screen or the video card?
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
Nov 10, 2009 | Toshiba Satellite P105-S6064 Notebook
Display is flickering and goes out and the screen become black. I attempted to hook up external display and get the same results. I think the issue may be a bad inverter card? System has winXP Home...
try tapping the LCD bezel, if you sense that the LCD would flicker, your hunch might be correct about the bad inverter card. it would also depend if the LCD type has an inverter. or worse case scenario - LCD is already failing...
Hope it helps!
Oct 26, 2009 | Gateway MX3215 Notebook
Screen looses display once logged on but works fine in safe mode
try starting into safe mode and set the display driver to a different resolution that you are sure your computer will display. it may also be an issue with the display adaptor when it switches to a specific resolution setting. windows loads your graphics settings at the time of log on.
Apr 18, 2009 | Gateway MX8711 Notebook
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | Gateway MX7118 Notebook
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
