Question about HP LaserJet 4000tn Printer
PRINTER WONT PRINT
I HAVE INSTALLED PRINTER TO MY COMPUTER VIA A USB CABLE IT WONT PRINT i HAVE IT ON PORT 1
    Genius:
  • 1,124 Answers
If you has been connected your printer via USB be sure that the printer port is "USB Virtual Port" and NOT Lpt1
Posted on Oct 07, 2008
  • Pablo Csaky
    Pablo Csaky Oct 07, 2008
    To check your port go to Control panel >> Printer >> Select the printer >> Properties >> Ports
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
HP 5P wont print on Vista
I deleted the email but still have the hard copy, so here goes. This worked with my 14 year old hp and a Dynex USB-Parallel cable.
1. Plug the printer to the USB-parallel printer cable and turn on printer.
2. Plug USB end to USB port on you computer.
3. When you do this, the computer will recognize the cable.
4. Go to Control Panel/Hardware/Device Manager/USB Controllers.
5. Make a click on the + icon and check if you have USB Printing Support
(If you are not able to locate it, unplug cable from USB port and plug it
back in, so you will see something that's new on the Serial Bus
Controllers).
6. Make a double click on USB Printing Support to open a new window
and look for device status. You should see a message "This device is
working properly".
Now you need to open a new com port for the printer:
1. Go to Control Panel and click printers & faxes.
2. You will see an icon there with the name of your printer, make a right
click over it and go to Properties.
3. Select the Port tab and on the display menu select Virtual USB Port.
If you have more than one select no. 1 first. If it does not work, select
Virtual USB Port, and so on. (The virtual port will depend exclusively on
what the printer requires).
4. Click Apply and try to print a test page.
I first hooked this up putting the USB cable into a port on the front of the computer and it worked fine. I then moved it to the back of the computer and it did not work, so I just had to go to the process again until I found a USB prt that worked. It has worked just fine ever since. This solution was given to me by Dynex Prodlucts customer care team. I am no techie and don't understand any of it, but I can follow instructions and it was successful. Gool luck.
Oct 02, 2009 | HP LaserJet 5p Printer
My HP LaserJet 2420 has disappeared from my "printers" control panel. The printer is connected via USB. I have swapped cables and have tried to install it on another computer with NO result. There are NO...
There might be a problem with your computer as well. Try printing with paralell cable to make sure the interface works at all. If the patalell-port works fine, try updating the printers firmware. Still problems ? Try with a different computer. If if works fine with another computer, then you know theres something wrong with your first computer. Good luck.
Aug 10, 2009 | HP Hewlett Packard LaserJet 2420 Printer
Have to keep setting up HPLJ 5P on a USB port everytime I print!
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 29, 2008 | HP LaserJet 5p Printer
'Communication Not Available' message when printer cable connect
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Nov 18, 2008 | Lexmark X2250 All-In-One InkJet Printer
RX620 wont communicate via powered USB hub.
on a windows system, go to printers and faxes, delete all icons there. unplug the printer, reboot your computer, then as soon as your computer is up, connect the usb cable... now wait.....
after about 5 mins, check printers and faxes if it has an icon for your printer, if it does then print a test page, if it does not show an icon, try another cable, try another usb port or try it on another computer entirely...
Sep 05, 2008 | Epson RX620 All-In-One InkJet Photo...
Error message and won't print
change the USB cable
tray to re install the usb port from device manager
Jun 29, 2008 | Brother HL 1240 Printer
Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
May 14, 2008 | Computers & Internet
Computer recognises printer but print requests not actioned
that happened to me with my cannon ip4300 so I installed the driver again so I had 2 drivers installed on the computer. The computer named the seconed instalation cannon (2) .
number 2 worked the first didnt.
so used number 2.
later deleted number 1 .still all ok
wierd but worked.
david267
Jan 27, 2008 | HP LaserJet 4L Printer
HP LaserJet 4000tn Printer Logo
119 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
