TV turns on, then shuts off, turns on then shuts off. Doesn't stay on for more than a minute. Sleep timer is off.
  • 41 Answers
Is this tv a lamp based unit? meaning does it have a lamp in it?
Posted on Oct 07, 2008
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
Powers off
check to see if our tv timers are on weekly or sleep timers may be causng the problem and shutting down and a given time
Oct 19, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sleep timer not a fix
This Tv is a piece of junk I have 2 of them and I had to replace the first one with this same problem. The second one just broke is stuck in dvd mode. Company is out of buissness
Dec 06, 2007 | Sony KDE-50XS955 50 in. Plasma HDTV
Nextvision n5
check your sleep timer settings. they stay on no matter how much you turn your unit on and off.
Oct 29, 2006 | ViewSonic NextVision N5 (n5-2) Video...
TV shuts off
there are some capacitors in the power area that need to be replaced. open the set and do some checking there and I am sure you will find the problem. good luck
Sep 04, 2006 | Daewoo DTQ-26S1FC 25" TV
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
