Question about Onkyo TX-SR603X Receiver
Powers off when I press the power button
I read in the user manual that this usually means that the amp protection circuit has been activated. It goes on to say that I should bring the unit to a dealer. Is there any way to reset this circuit without sending into the service center?
  • 1 more comment
  • jalex08844 Oct 07, 2008
    Thanks. This unit has been off for over a week now. It shut down while in use and the cabinet felt very warm, but I unplugged it the moment the component failed.
    So if the circuit resets itself after cooling down and it hasn't done so yet then it sounds likely that a repair visit is needed, would you agree?
  • Anonymous Dec 22, 2008
    whem i tray to turn on is going to stan by
  • cevans276 Apr 06, 2009
    My onkyo tx-sr603x does the same thing. I took it to an onkyo repair center and they could not get the receiver to duplicate the problem. It goes into circuit protection from standby instead of powering up correctly.
  • 599 Answers
It resets itself when cool..something is causing it to trip that is non serviceable ,or rather, Should be serviced by them
Posted on Oct 07, 2008
  • milespeed Oct 07, 2008
    completely agree..and should be a completely warranted issue unless they can blame a power spike from your source...which is unlikely if you have other components also running off same source and they are fine ..:)) good luck and keep us posted
My unit powers up and then goes to protect, why?
This usually means there is a short in the amp section. It needs to be looked at by a pro.
Nov 20, 2012 | Sony STR-DE345 Receiver
Tv switch on and off when press power button
IF power light comes on for a moment and then goes off:
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Jun 21, 2011 | Mitsubishi WS-65511 65" Rear Projection...
TV will not turn on. Push power button green
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
If it is 2,2 I have START TO FINISH STEP BY STEP INSTRUCTIONS AND PHOTOS TO SHOW YOU WHERE THE FUSES & PROTECT RESISTORS FOR THEM ARE LOCATED.
The instructions tell you everything you will need for the repair and how to do it.
You can buy all the parts needed for less than 30 dollars on Ebay (I know the best seller there) I have repaired hundreds of these sets with this problem
If this information has helped you rate this solution as I do this here for free.
If you want the instructions & photos let me know and I will post them here for free.
SD TECH
Dec 09, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My Onkyo TX-SR700 AV Receiver shuts off about 10 seconds after I turn it on ?
Please remove speaker wires from receiver and turn it ON, if receiver still goes to standby that means it got problem in amplifier output section and protection circuit gets activate to turn it off.
If removing speakers solve turn-off problem that shows any of speaker is bad, connect speakers one by one to find out what speaker causing protection circuit activation.
And if receiver has problem with internal circuit, a tech would be fine to diagnose that kind of problem because it is not user level repair as it requires testing voltages in output circuit of receiver and also requires soldering work to replace defective parts.
Thanks.
Sep 12, 2009 | Audio Players & Recorders
My amps protection circuit keeps cutting on and off when i hook up my amp
Hello m_george191,
Usually an amp will go into protection when there is a problem with the wiring, impedance load, or when overheated. Immediately when hooked up, it probably isn't overheating.
Most likely, there's a short or ground on a speaker wire, an input, or a faulty ground to the amp itself. Frayed or broken insulation, stray wires shorting across the terminal blocks, and shorted voice coils can all cause the protection circuit to activate.
First check your power and ground wires. Then disconnect the speakers and inputs and see if the amp powers up normally. If the amp still goes into protection with all wires other than 12V +, Ground, and Remote disconnected, the amp itself is defective. If it powers up normally with all other wires disconnected, reconnect the inputs one at a time to determine if one of them causing the problem. Likewise, reconnect the speaker wires one at a time.
Hope this helps.
Aug 31, 2009 | Rockford Fosgate Punch P325.2 80W x 2 Car...
Red protection light wont turn 2 green no matter what so the amp wont work
Hello mcis43fan,
The protection circuit can be activated by shorted or grounded wiring or it can be caused by a defect in the amp itself.
First, disconnect all wires except power, ground and the remote turn-on lead and see if the amp powers up normally. If it still goes into protection, the amp is defective, most likely shorted outputs and needs repair or replacement. If the amp powers up normally, test the other wiring for shorts and grounds. You can reconnect them one at a time to determine which one is causing the problem.
Hope this helps.
Aug 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
The tv will not turn on
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Jul 15, 2009 | Broksonic CCVG-3276 32 in. LCD TV
Standby light keeps blinking. tv wont turn on
connected.
May 07, 2009 | Televison & Video
The amp protection circuit was actived - what should we do?
Remove all speaker wires from the receiver and turn it on.
If it still goes into protect, I'll bet the house that one of the channels is shorted out and it needs repair. This is a job for a pro.
If it doesn't go into protect, check for a short in the speaker wire or for a bad speaker.
Jan 28, 2009 | Onkyo TX-SR605 Receiver
Tv powers on and goes off after about 3 seconds
This set has a problem in the horizontal sweep circuit or in the main power supply. Most likely a failed component, and the set shut down to protect the rest of the circuit. If you know how to read a schematic diagram and how the circuits operate, then you will need a good multimeter and an ESR type capacitor checker to find out the short in this set. Sometimes the CRTs(Picture Tubes) will leak the coolent fluid out and onto the printed circuit boards. Also sometimes the convergence IC's can cause this problem, but if that is the case the small little pico fuses will pop also. If you have had no solid state or printed circuit repair experience, play it safe and call in a trained tech. Good Luck
Mar 17, 2007 | Mitsubishi WS-55907 55" Rear Projection...
Onkyo TX-SR603X Receiver Logo
254 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
