Question about Philips ProScreen 4650 Multimedia Projector
HOW CHANGE DE BULB?
I NEED CHANGE DE BULB'S PROJECTOR, HOW I DO IT? I DON'T HAVE THE USER GUIDE.
On the side you plug everything to.... has 2 screws.remove them ..after completly removing screws..remove cover plate remove the 2 screws holding the bulb housing... you will see a hinged flap pull on this and the whole unit comes out..DO NOT REMOVE IF BULB IS HOT!!!!!
The new bulb comes with a new housing Please do not touch the bulb the oil from your hands will reduce the life of your bulb..Slide the new one in put the screws back, , the cover back and thats it
Posted on Jan 26, 2009
HP VP6111 Projector. problem: From day one when I bought it brand new, this projector had problems starting the bulb. Everytime I didn't use the projector for some time, when I tried to turn it on it...
It is a pity you did not return it after the first problem. If it is still under Warranty, I suggest you do now. Even if it is out of time, it is still 'not fit for purpose '
Mar 13, 2014 | HP VP6111 Multimedia Projector
Buy new bulb
Search for the 3-alpha ANSI code that is on the lamp online. If you can't read it, or don't have the user guide to identify the correct lamp, try: www.bulbs.com or www.bulbman.com
Both are good sources for all kinds of lamps, and they usually have reference guides that will allow you to identify the exact lamp you need for your projector! Good Luck !!
Mar 06, 2012 | Braun Office Equipment & Supplies
Lamp light stays solid red . i already replaced bulb. any solutions?
Check your owners manual for diagnostics. You can find all documentation for your VT595/695 projector on the NEC support site.
The users guide indicates that the lamp timer needs to be reset. Instructions can be found on page 49 of the users guide.
Press and hold the HELP button on the remote control for 10 seconds to reset the timer.
Feb 05, 2010 | NEC VT595 LCD Projector
Proyector 3m mp 8670
the lamp is ok
the lcd panels were fault
you need a new one
USD160
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Nov 06, 2008 | 3M Projector lamp Projector Lamp
Won't power up at all
There is a chance that it is fuse protected inside.
When a filament-equipped lamp fails, it can create a momentary surge; you've probably seen this when a standard tungsten bulb flashes very bright in the process of dying completely.
If you no longer have the User Guide, you can download it here:
http://safemanuals.com/user-guide-instructions-owner-manual/ACER/PD120-_E
It may contain information about any fuse it uses.
Aug 25, 2008 | Acer PD120D Multimedia Projector
Philips ProScreen 4650 Multimedia Projector Logo
224 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
