Question about Tools & Hardware - Others
Wiring help for Electric Hoist Cummins #6832
I have a problem with this hoist, I am fixing it for a friend. Unfortunately the Forward/Reverse switch was already disconnected, before I got into it, the switch is a Mom-Off-Mom DPDT switch. The motor has only three wires going into it, which control the forward, reverse and electric brake functions. There is also a large 70uf electrolytic capacitor, which was disconnected. Any info on the motor would be a great help (110vac-60hz). I have reverse engineered a partial wiring diagram, but it's not much help, without knowing how to wire the motor. My email is emjensen@fmctc.com Thanks in advance.
  • beach42 Jan 12, 2009
    I have the same hoist the control wires were pulled from the motor housing. Iwould like to see a wiring digram.
    beach42@datasync.com
SOURCE: wires on switch
On my rotary tool the white wire goes on the left if pointed away from me. Hope this helps. Mamabear
Posted on Oct 03, 2008
protek480
  • 1723 Answers
SOURCE: how to wire a 110v reversible motor to three-way
I have a diagram I made s few months ago for one of my customers. I will sen it on to you later today. It is a bit tricky...Craig
Posted on Sep 08, 2009
  • 91 Answers
SOURCE: MinnKota Endura 50 Runs only in high speed in forward and reverse
the coil pack is likely bad especially since you changed the switch. call minkota and get the bench tast info (very simple) and then order and replace the coil pack about 26 dollars. be very careful how you put the magnet assembly back together and mark the position of the case on the outside before disassembly. order a new seal kit and use locktite on the shaft again when reassemling to seal the shaft tube for water. dont run motor uout of the water much as it uses the water to cool the shaft and you can damage the seals. good luck.
Posted on May 16, 2010
SOURCE: I need a basic wiring diagram for a 3spd, 3 wire
Try L-BLACK 1-GRAY 2-BROWN 3-PURPLE. IF THIS COMBO DOESN'T WORK. BLACK WIRE GOES TO L , 123 IS YOUR SPEEDS YOU WILL HAVE HOOK THEM UP BY PROCESS OF ELIMINATION FIGURE OUT WHICH IS HIGH MED & LOW. IT SHOULD BE 1-HIGH 2-MED 3-LOW.
Posted on Jul 27, 2010
heatman101
  • 43501 Answers
SOURCE: The electric motor for my
Before removing the motor I would check for sure that you are getting power to the motor...if so then the motor is gone...there could be an internal overload that went out on it....
Check your yellow pages for a motor repair shop, many times they can fix the motor for a few bucks and they will give you an estimate before you okay the repair.
heatman101
Posted on Nov 16, 2010
Looking for a parts list for a Dayton 3Z372b electric hoist.
Dayton Hoist Parts - Ace Industries, Inc.
https://www.aceindustries.com/m-53-dayton-hoist-parts.aspx
Dayton Hoist Parts Online. Certified OEM DaytonParts in Stock Helpful Diagrams to Find Parts Fast. ...Dayton Electric Chain Hoist Parts. Basic Hoist(Figure 12) ...
[PDF]Dayton® Electric Chain Hoists - Ace Industries, Inc.
www.aceindustries.com/pdfs/Dayton/DaytonElectricChain-JLCManual.pdf
Dayton electric chain hoists are rugged, portablehoists that provide quick, precise ... Other features that ensure the safe operation of Dayton electricchain hoists.
Dayton Hoists Online - Ace Industries, Inc.
www.aceindustries.com/m-52-dayton.aspx
Coffing hoists and the Grainger Dayton electric hoists are the same identical units. The only
Apr 19, 2016 | Dayton Heating & Cooling
How do i fix an electric hoist for a loft
The motors aren't really serviceable, they need to be replaced. Can you give a little more detail about what the problem is that you're having with the lift?
Jul 30, 2013 | Kayak Hoist System
Tirak T3000 Hoist
Wow thanks for this. I was wondering if any one would know where I can get a <a href="http://www.legerpalans.com/anglais/pages/vente/palans.html">hoist</a>? If you know where I can get one please let me know. Thanks for any help.
Mar 26, 2013 | Computers & Internet
I can't find information on my chain hoist anywhere. what are some other names for the chain hoist?
the manual chain hoist can also be called the chain block, block and tackle, hand chain hoist, or manual chain block
Jan 16, 2013 | Hoisting
Transmission oil location on a golf 3 gsx
I would recommend checking the fluid, whick may require a hoist depending on year. But Volkswagen is inherit for reverse noises that sound alarming but will never cause a failure.
Nov 20, 2012 | Cars & Trucks
I purchased a radsportz kayak hoist which appears to be a sturdy, high quality product. The instructions say to position the two pullies no less than 6 feet 8 inches apart, but I need the hoist for a short...
you should be fine to go shorter. The reason for the 6-8 foot recommendation is balance. a 12-14 foot kayak would risk tipping it you had a 4-foot width and didn't denter it just right. Your shorter kayak should do fine at 4 ft, but I would be careful to center.
Jul 09, 2010 | HOIST NEW Kayak / Canoe Lift Hoist by RAD...
How to run 24 volt wheelchair hoist from 12volt supply
You can have two 12v batteries in series, and to charge them go to a camper supply store and buy an isolator. You will have to rig up the switching to go from charge mode to wheelchair hoist operation mode so that you won't burn out the alternator. (The two processes must operate independently.) This is the best way to go on this, rather than to try to modify the hoist mechanizm.
Nov 21, 2009 | HOIST Cycling
I need to take out my motor from my honda civic 1994 and put in anothe one from a honda del sol 1992.How do i do that???
Ensure first that you have the proper tools first such as hoist for the engine. You need to unplug all of the wiring from the engine. If possible use the same wiring harness without removing the protection. Secure the engine to the hoist and remove the engine support. As far as I know the engine should bolt on to the other car, just do the reverse of the process.
Nov 02, 2009 | 1994 Honda Civic
DAYTON 9K602F HOIST WIRING
false alarm-schematic in cover of unit
Apr 09, 2009 | Dayton Electric Hoist Heater
Tools & Hardware - Others Logo
1,053 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
