Question about Maytag MGR5875QD CleanDesign Gas Kitchen Range
Oven does not work
Broiler and stovetop work. Oven does not. Any ideas?
Thank you. Wayne
  • peppa81 Jan 06, 2009
    stovetop & broiler work on my oven. When I push "bake", the oven beeps and says F3
  • Anonymous Feb 09, 2009
    Just days ago the oven did not work. When I kept trying to get it going, it finally did. The next day it did not work again. The broiler works, however.
Oven and broiler wont work
Posted on Oct 16, 2008
I have a GE profile spectra JGBP79... the oven has stopped working. the broiler and stovetop work, just not the oven. any idea what's going on? it's been taking a while for the oven to warm up, so i guess...
Your oven ignitor is bad. To get to it remove racks from oven. Remove bottom shelf in oven. Removevmetal plate covering flame spreader if thete is one. Ignitor is located towatds the back right by the flame spreader. Turn oven on, pay attention to the ignitor, It should gove off a real bright glow. If it doesnt it needs to be changed
Feb 17, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven heating element isn't working, but the broiler is working. The stovetop works fine.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 19, 2011 | Kenmore 95032 / 95034 Electric Kitchen...
My stovetop works but my oven will not ignite.
Try this...open broiler door while initiating an oven start...look to the rear inside the broiler...there should be a reddish glow occuring...if not, then the ignitor may have gone bad...these are available from appliance parts stores or online
Dec 20, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
GE XL44 Oven and stovetop work - broiler does not work
The broiler is the top element in the oven. Look at it. Bad ones sometimes have burnt into or have a melted spot. If it looks ok take it out by removing the screws at the back and pull the wires out a little and unplug the element. With an ohm meter it should show continuity. Replace it if any of these things apply.
Feb 04, 2010 | GE Kitchen Ranges
No oven baking function
You need to replace the oven ignitor. The ignitor has to draw enough current to open the gas valve. Your ignitor is either broke or not working properly, so the ignitor will not lite the oven.
Jan 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Oven and Broiler not working
The gas supply valve to the oven/broiler is the likely culprit. It is a separate valve from the stovetop. I've had the same problems and had to replace mine twice now. They are very expensive, (about 100 dollars) considering the cost of the whole stove. It is located
inside the broiler drawer on the very back wall.
Jan 01, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
I have a Frigidaire Gallery gas oven (electronic digital controls). Neither oven nor broiler is lighting. Stovetop burners light fine.
Have to check if there is power at the oven & broiler first.Maybe a bad thermostat located in back of oven wall.
Jun 08, 2008 | Frigidaire Kitchen Ranges
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Maytag MGR5875QD CleanDesign Gas Kitchen Range Logo
193 people viewed this question
Top Maytag Kitchen Ranges Experts
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
