Question about Kenmore 2303x Top Load Washer
Kenmore Elite Washer Model 11023032100 Motor Binds smell elec burn
My Kenmore washer often locks up when I start a load of wash. The tub fills with water appropriately but the agitator won't spin. You can hear the timer "buzzing" as if in a bind and you can smell the "burning' of one of the contacts on the timer (could be the motor too... don't really know). I had a Sears repairman come out today and charge me $65 to tell me it was a burnt contact on the timer. He wanted $297 for parts and labor to do the repair, so I declined, bought the part myself for $136 and installed it... but I still have the same problem. I think it has to be something with the motor or pump. If I let the machine stay in a "bind" and let the timer cycle, it will eventually go back to working as it switches between washing to rinse. I have also noticed that it doesn't seem to spin as fast as it used to on the spin cycle. Does anyone know if i should be looking at the motor or the pump in regards to this problem? I've also read a little about clutch problems... any help would be very welcome.
Thanks!
  • 5,911 Answers
I can assure you that the pump has nothing to do with the spinning of the washer. The pump is actually driven by the Drive Motor. It sounds like to me that you either have a Drive Motor binding up, or the start switch for the motor is bad. Since you mentioned the spinning seems slower than usual, I'm more towards a motor problem. Searspartsdirect.com carries both parts. Just type in your model number and look under the "Brake/Clutch/Gearcase/Motor and Pump" heading for items 19 and 20. Item 19 is the motor and the switch together. Item 20 is just for the switch. Your wiring diagram (located inside the operator console) should tell you which pins to check on the the start switch to confirm if it energizing as it should. If you require instructions on how to replace a drive motor the following link explains:
http://www.fixya.com/support/r599953-replacing_drive_motor_kenmore_or
Now...to digress just a moment before I put my foot in my mouth...IF, you have something lodged inside the drain pump that is preventing the pump impeller from turning, it could potentially cause the motor to bind. However, eventually the center post hole on the back of the pump would round out due to the torque of the motor and/or the washer would stop draining.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Oct 07, 2008
I have a GE washing machine model # WCSR2090DAWW and today I went to put a load of clothes washing. It filled the tub up with water like normal and then went into soak mode. The problem starts when it...
Possible that some item of clothing is jamming up the drive to the tub. The burning smell are the motor windings reacting to the excess of electricity flowing thru them before they burn out.
Apr 02, 2017 | GE Appliances 3.5 cu. ft. King Size...
Model # 110.22064101 Kenmore calypso elite washer makes a whirring sound when washing and the washer tub doesn't always stop correctly when the cycle is complete. It will move around instead of being...
The motor coupling is about to completly go out on you and then it will not spin at all. This is common on these machines. the repair should be under $100.00. The motor brake may also be dragging.
Nov 10, 2010 | Kenmore 24032\24036 Top Load Washer
Motor just hums.
I NEED YOU R MODEL NUMBER FOUND AROUND WASHER TUB OPENING SHOULD HAVE NUMBERS AND/OR LETTERS I YIELD NOTHING WITH 23032
Apr 11, 2009 | Kenmore 2303x Top Load Washer
Washer works but smells like its burning.kenmore 90 series heavy
The burning smell could be the motor going out. When the water gets into the tub and makes it heavy it puts strain on the motor and the motor may be getting weak.
Feb 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite washer, model # 22942101 Spin cycle not working. The water drained out but the drum does not spin. It smells as if something burned out.
If the water drained out, then it sounds like the motor is still good.
I would check if the brake were failed in some manner since you smelled something, and if that is OK, then it's probably a failed gearbox.
Jan 27, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 2303x Top Load Washer Logo
300 people viewed this question
Sal De
fordexpert
Robert Rankin
