Question about HP Compaq nc6320 Notebook
Hp nc6320 boot issue
My laptop will power up for no more than 6 seconds and immediately shutdown. It will not stay on long enough to see the boot options that come on as soon as the laptop powers on. There is no time to see anything on the screen, it never makes it that far before powering down
  • 538 Answers
Try this with only the power cord and no battery installed..if that works..then slip the battery back in..and let it charge for around 2 hours..
Posted on Oct 09, 2008
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Intermittent power
verizon put in a shutdown code so you cant get to verizon program to shut it down, the only answer i know of is to install a net hard drive
Oct 07, 2013 | HP Compaq nx6110 PC Laptop
HP M7357c overheating problem
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 03, 2012 | HP m7357c PC Desktop
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
Oct 09, 2009 | HP Compaq nc6320 Notebook
Display not working for HP pavilion dv2000
Try to attach your computer to an external monitor to see if it is a screen issue or a motherboard issue. If the computer does not pick up on the external right away, try to toggle it by holding down the Fn key and striking F4. If you get a picture on the external, then you have only lost the screen and the motherboard shouyld be fine.
Sep 20, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Power failer
You need to check the voltage on the power adapter. If it checks out, you will need to call HP because this is an issue that is typically caused by power surge and motherboard replacement is usually the solution.
Jul 15, 2009 | HP 413670-001 - HP Compaq nc6320, nx6310,...
Laptop Screen goes blank
Are you running on battery or AC? Try using the power cord, remove the battery and see if it continues. I have seen a battery that is on its last legs do some weird things to a computer. Also, check your power management setting. Control panel, power, and set the computer to "always on" just to see if it could be a power management setting. If none of this works, i would back up all your files, and try to reload win xp from scratch.
Jun 23, 2009 | HP Compaq nc6320 Notebook
Evo N610c Laptop. I get an attempt to start and an immediate shutdown every
can u get in bios remve all power then plug back in not off battery use direct plug defult new bios f1 f2 f11 ect
Oct 07, 2008 | HP Compaq Evo n610c Notebook
HP Compaq nc6320 Boot Disk
in case you can get a non boot disk , u can install it by using a start up floppy disk for win9x
Nov 15, 2007 | HP Compaq nc6320 Notebook
Nc6320 Laptop power
hello the first thing to make sure of is that the ac adaptor cable is not having any partial contacts ofany kind whereby power gets into the laptop irregularly.this could have adverse effect on the circuitry. it is not enough just checking the output of the ac adapter by a meter.try straighten the cable from the adapter and check the meter for voltage fluctuations. if the above is okay then the problem could be on board leve.
Aug 10, 2007 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Notebook Logo
194 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
