Question about Brother MFC 4800 All-In-One Laser Printer
Print out results all in black
Hi guys ... i wish you could help me my fax machine lately were printing a plain paper id loaded all in black.. i mean all covered with black.. toner i guess... thanks in advance..
erwin
  • patriciatj Feb 17, 2009
    copies and prints from PC 100% black. No images at all. I have alrady repalce my drum 6 months ago and I do not have a message sayin gthe drum is bad.
    No warning and worked fine until a few a hours ago.
I simply replaced the drum... thats it..
Posted on Oct 15, 2008
My fax machine states 'fax RX in memory' and does not receive any faxes?
There is a Fax in memory. Either, the machine has a paper jam, is out of paper, or needs the ink cartridge replaced. Fix the above and the fax will print and the machine should work in Fax mode again.
For a unit with paper and no paper jam, try adjusting the paper stack and check if the unit picks up the paper properly. If you have ink in the cartridge, try cleaning the print nozzles and contacts. If a nozzle cleaning from the unit doesn't work, do it manually. Use a damp cloth (lint-free) and wipe in one direction only. Dampen the cloth with bottled or distilled water for best results. See your manual for pictures.
If you need the manual, try the Sharp site or http://www.retrevo.com/support/Sharp-UX-B700-Fax-Machines-manual/id/310bh149/t/2/ .
I hope this helps.
Jan 14, 2011 | Sharp UX B700 Plain Paper Inkjet Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
I wish to buy operating manual
go to panasonic,com and down load manual for your model number
Feb 02, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Paper jam
sounds like you have a problem with the mechanicals, have it check by a certified tech. or junk it....hehehe!!!!
Jul 24, 2008 | Panasonic KX-FP101 Plain Paper Thermal Fax
Dirty roller?
what does "behind the print mean"? on the back side of the paper ?
Jan 24, 2008 | Xerox FaxCentre 1012 Plain Paper Laser
How Can I Reprint a Fax?
Here's a trick that I used on the Canon thermal transfer years ago. First take out the thermal transfer unit and roll up the black transfer sheet to the begining of the lost fax. Then reload the paper. Next get a solid black original equal and make a copy. The result you should get a negative copy of the lost fax. Repeat this step until all the faxes are recovered..
May 31, 2007 | Panasonic KX-FC195E Plain Paper Thermal...
Brother MFC 4800 All-In-One Laser Printer Logo
100 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
