Question about Dewalt 2 Hp 4 GAL Air Compressor
(I need a new electric motor for my air compressor. Where do I find one?
  1. One of two small electric motors that runs the pump.
  2. A ronning motor cc-5440m12 120v/60hz
  3. Who can I contact regarding the purchase of one of these motors?
  • 5 more comments
  • GUNRAMS Nov 10, 2008
    HI THERE ,,I HAVE A 26 GALLON COMPRESSOR ,,,,THE DAY AFTER I GOT IT ,,BOOM NOW I SIT HERE WITH VERY LITLE MONEY AND A NEED FOR A NEW MOTOR ,,,,BACK OF THE TANK SAYS ...MCO30300AV ,,,,THE MOTOR NUMBER IS WL611105AJ ANY HELP WOULD BE GREAT ,,,THE MOTOR SAYS IT HAS 5.5 RUNING HORSE
  • Mikestem Nov 20, 2008
    Same problem: One of two Ronning Motors in a Campbell Housefeld FP2020 died.  Service dealer said it wasn't worth it to replace, might cost $130.00 for new motor unit.  I can replace it myself, if I can find the motor cheap enough.
  • mtjrogers Jan 15, 2009
    Mikestem,
    I have the same problem. All along i thought that Cambell hausfield was a good air compressor. I am going to try to get them to replace the motor under warenty since i have only had it for 2 weeks. I was using this compressor for an air bush. After a little use it started to making a diffrent sound then stoped all together. When i find an answer to this problem i will post it. If anyone has a motor that will fit this compressor please let me know. I have tried Grainger and baldor site but there is not enough information listed on this Ronning cc- 5440m12 motor to find a correct replacement. If there is someone that has a good sugestion please let us know.
  • chuckerj Mar 20, 2009
    I think I can help you guys needing a replacement CC-5440M12 120V/60Hz Ronning Motor. I have been cleaning out my shop and I have four (4) of these USED electric motors. All work fine. They still have the plastic fan blade on one end and the metal gear on the other. I actually have electric cords wired up on each of them that I used to make sure they worked.
    Thought I would pass this information on to you in case any of you were still looking for replacement motors. I will sell these used electric motors CHEAP to get them out of my way and to help with your motor issues.
    Thanks and have a great day.
  • gkolan Apr 01, 2009
    I need a Ronning Motor, model# CC-5440M12 for an air compressor. Can anyone help me find one. thanks, gkolan
  • ajlees Apr 08, 2009
    Does chuckerj still have motors left. How do I contact him??
    ajlees@att.net The CC-5440M12 motors.
  • Anonymous Apr 26, 2009
    looking for a motor CC5440M12 used or new ...crazy that the company does not even have replacement motors available... so do i just chuck it in the landfill and buy a new
I think I can help you guys needing a replacement CC-5440M12 120V/60Hz Ronning Motor. I have been cleaning out my shop and I have four (4) of these used electric motors. All work fine. They still have the plastic fan blade on one end and the metal gear on the other. I actually have electric cords wired up on each of them that I used to make sure they worked.
Thought I would pass this information on to you. Thanks and have a great day.
Posted on Mar 19, 2009
  • 2 more comments
  • Martin Smethurst Nov 04, 2013
    hi chuckerj.i read your post and have been looking for the same motor.do you still have any left.if so i am interested.
  • Luis Romo
    Luis Romo Nov 21, 2013
    Do still have these motors? I need one if possible.
  • Robert Bartho
    Robert Bartho Dec 03, 2013
    yes, I need the same electric motor
  • K Rod Kimmel
    K Rod Kimmel May 25, 2016
    This post was a long time ago, but I need one of those motors. shvlhead68@gmail.com
I had the same problem and discovered that the brushed were worn out. While in the Dremel dept at home depot I noticed that the replacement brushes for model 300 ( they also fit most other Dremel tools) were very close to the size from the motor on my compressor. For under 4 dollars it was worth a try. They are actually just slightly larger so you need to sand them down on all 4 sides, go slow and keep trying for fit. Even the springs included will work, I just stuffed the whole thing in and reattached the contact clips. The graphite is softer than the originals so you may not get as much life but for the cost, it beats buying the whole motor assy. Good Luck, Mike
Posted on Aug 03, 2010
  • 59 Answers
Grainger will have match motor for you. or go to baldor motors web site and ordere it.
Posted on Oct 07, 2008
What type oil for model 90234 4 HP 10 gallon
The model number is not enough info but assuming it's a run of the mill, Home Depot or Craftsman type electric air compressor, you need to buy compressor pump oil at Wal Mart or an auto parts store. Please don't use Automotive motor oil because that's not going to withstand the heat of your compressor pump and you'll be buying a new compressor because of it. If your compressor has a gasoline, 4 Hp. motor, it needs Mobil 1 synthetic and change it after every 30 hours of operation.
May 19, 2017 | HP Air Tools & Compressors
Will an electric motor with more horsepower and more rpm hurt a compressor pump?
Electric motors seem to turn around 1125 rpm or 3600 rpm. The pulley size on the motor and pump must be adjusted to achieve the desired result without overheating /loading the motor. I have seen pumps turning from 800 to 1200 rpm using different pulley size on motor, motor hp and motor rpm. Some brands will turn same pump from 1200 to 3600 rpm depending on if was electric or gas motor. This will certainly shorten the life of the pump but will most likely work. Most turn an average of 1200 rpm for good balance of long life and good supply of air. Pump rpm is usually limited to the power of the motor. Cost effective match of 1.5 hp motor will turn pump about 1000 - 1200 rpm for about 5cfm. Rol Air 2hp motor turns 2 cyl pump about 1100 rpm for 10 cfm. Good luck
Mar 17, 2015 | Campbell Hausfeld Tank Air Compressor, 1...
I have a IR air compressor 30T Series with no motor, pump model number 253-7D. I need to know what size electric motor to put on it.
You can use a range of motors from 5hp electric to 10 - 13 hp gas. Depends more your output requirements. Need lots of air, turn fast, not so much as small shop, turn slower. Just watch min and max rpm and direction. Adjust load on the motor with pulley size. Lots of information about this pump at www.grainger.com and also at www.northern.com. I have a Quincy 325 running at only 500 rpm with 5hp motor gives me plenty of air but could use larger motor and turn maybe 900 rpm for super quick shut off (seems like a waste for me). Good luck with your project.
Jun 10, 2012 | Ingersoll Air Tools & Compressors
Its hard for me to describe in technical terms what is going on with this unit. There is a leak behind the part that holds the 2 air gauges. There is a very small diameter hose that is about 12-14 inches...
Your infeed valve is stuck/broke in the open position. As you are looking at the motor/pump side of the compressor, on the right side of the top tank there is a brass valve that has leading into it a copper tube from the pump and the small black tube from the pressure switch. This valve lets air into the tank from the pump but should close when the pump turns off. When the motor turns off the black tube lets air bleed out of the pump and copper line so the motor can turn over when the pressure switch turns it on again. You need to contact Hitachi or one of their service centers to find out which infeed valve you need, they ahve different part numbers depending on what year your compressor was made. Go to http://www.hitachipowertools.com/index.aspx and use either their contact us page or the search for your nearest service center page and they should be able to tell you what part number you need.
Jan 28, 2011 | Hitachi EC12 Portable Electric 2hp Air...
On start up, the motor ran slow then popped the circuit. plugged it into a 20 amp circuit, it ran a little stronger then shut off without popping the circuit. Motor was hot, and after a short period the...
It sounds like the compressor is trying to start under load because there is a tightness in the pump itself or there is high pressure air in the line between the pump and tank There is a small valve that releases the pressure out of the main pipe that runs between the compressor and tank once the tank is full and the motor automatically cuts off. You know this valve is working by the sound of a short spurt if air being released when the motor cuts off. Releasing this pressure means that the motor is able to restart easily because there is no load. If the valve is not releasing this air, the compressor is trying to start under full load which the motor is not capable of doing, hence the slow running, overheating and popping of breakers due to a current overload as the motor tries to run up to normal peed. Motor burnout is possible if it keeps recurring.
This small release valve is attached to the Pressure control switch that switches the motor On & Off and usually has a small pipe going to it or is incorporated inside the Pressure Control Switch. If the valve appears to be working then it means that the Non-return valve on the input to the tank is not sealing properly and letting air back into the main pipe causing the compressor to start under load. Check both valves for correct operation and replace as necessary.
If all the air side checks out OK the check for low oil level and / or binding in the air pump main drive shaft.
Dec 11, 2010 | Craftsman 33 gal Air Compressor 6 hp...
Pump humms and barely turns. Fan blade caught wire caused huge spark. wire has been replaced.pump does not really seem to get going and trips safety after a minute of running.
hi there!
short circuited at start damage motor compressor
if you have a service center for motor compressor have checked this one, motor compressor has thermal overload protection mostly on single phase motor inside the motor,in the absence of overload protector the winding of motor on start and running maybe shor circuited.this should be rewind by motor rewinder.check the cost of motor rewind to a brand new motor.have choose n it.have a nice day fix my rate.
May 07, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I have a Hitachi compressor EC12. Sometimes when
you may have some water build up pull the cover apart look at yor pistons for build up
Jan 07, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Unit was running and shut off. Now motor won't run. Seems to get initial click and then a hum.
Try trouble shooting it in this order
1. remove the v-belt connecting the motor and compressor
2. run the motor, if it runs well then check the compressor. try to turn the flywheel of the compressor by hand. if it turns alright then check the pressure switch.
3. check the setting of the pressure switch, it cuts off power to the motor when the preset pressure is reached, maybe it is set too low, adjust the pressure switch to a higher setting
Oct 18, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Motor pulley for an old Ingersoll Rand type 30 compressor
Here is a link to Ingersoll-Rand (compressed air division) where you can find a local distributor. I think a call to a parts tech might provide the original motor sheave outside diameter and belt size (I'm suspecting "A" or "B" size).
http://www.ingersollrandproducts.com/contact/air/index.aspx
With that info, here is a link to a good industrial source for your new motor sheave (McMaster-Carr):
http://www.mcmaster.com/#v-belt-sheaves/=3fwz7b
Their prices aren't so bad.
You may also have a local industrial sales in your area.
I hope this helps you... Nice compressor!
Sep 01, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Electric motor labors when restarting
to long of a cord or to small of Gage wise or filters are clogged or compactor on the motor is going bad.
Jun 28, 2009 | Coleman CP0302013 20 - Gallon Portable...
Dewalt 2 Hp 4 GAL Air Compressor Logo
2,874 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
