Question about RCA OPAL M4001 MP3 Player
RCA Opal MP3 player stuck on "keys locked"
Hey Ginko, I've got an RCA Opal 2GB Mp3 player, with a "keys locked" problem. Apparently this is common with this MP3 player, as it has been mentioned a lot in other reviews. I put some songs into it, and now it just says this message and then quickly shuts down. I've already reset it a bunch of times with no avail. Can you help me?
-Don
Thank you .... I feel like an idiot because it was so easy... just put the hold button back...
Posted on Oct 19, 2008
  • RCA Master
  • 19,396 Answers
Push down the key lock switch, I think on your model it is on the side of the unit.
If it does not work, try performing the reset procedure below, From
ThaMp3Doctor
I quote
"Opal has a reset hole on the back of the unit in which atoothpick (non metallic) can be inserted to reboot the player. If thisdoes not work, I suggest that you reformat the player by using theWindows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device. "
If it still does not work, then the lock switch is probably faulty or stuck inside, in this case you need to take apart the unit, to fix it.
Try playing with the lock switch, or resetting the unit, that should unlocck your MP3.
Posted on Oct 07, 2008
How do i put videos on my opal mp3
Log onto the RCA website and download the RCA SMV Video Converter. The Opal only plays videos that are in one specific format. This converter will put your videos into that exact format (see Resources below).
  • Install the RCA SMV Video Converter once you have downloaded the software.
  • Open the RCA SMV Video Converter software to begin putting videos onto your RCA Opal.
  • Connect the RCA Opal to your computer using the USB chord that came with the device.
  • Wait until the RCA SMV Video Converter software reads that the device has been connected. You will know this when the bottom of the software screen reads “Player Detected: Opal 1GB 2GB.”
  • Select the “Browse” option to find any videos that are on your computer which you wish to add to the RCA Opal.
  • Click the box next to “Transfer output files to OPAL 1GB 2GB after conversion is complete” after you have selected all of the videos which you wish to convert. This will automatically add the videos to your RCA Opal after they have been converted.
  • Click the “Convert” box after you have selected all of the videos. The videos will automatically begin to convert to the correct format. Once they have been converted, your videos will automatically upload to your RCA Opal.
  • Oct 04, 2009 | RCA OPAL M4001 MP3 Player
    I have a RCA opal mp3 player that turns on and stays on the same
    Follow these instructions to put your player in recovery mode:
    http://voxrightnow.custhelp.com/app/answers/detail/a_id/2200
    Jul 12, 2009 | RCA M4208 MP3 Player
    Problems with my rca opal mp3 m4oo2 2GB
    remove software for the opal from you're computer an components reinstall software the go from there.
    Mar 23, 2009 | RCA OPAL M4001 MP3 Player
    Firmware for my rca opal m4208rd
    This is a very common problem with the RCA Opal.
    You need to goto the RCA website and download the latest firmware.
    http://www.rcaaudiovideo.com/product.aspx?product=408
    Download the firmware from there. Plug in your mp3 player. (don't worry if it cant be found bye the PC it will when the firmware installs)
    After the mp3 player is plugged into the usb device of your pc install the newly downloaded firmware. And it should work fine.
    Jan 27, 2009 | RCA M4208 MP3 Player
    Turning on, "keys locked" message
    ON THE SIDE OF YOUR OPAL MP3 PLAYER THERE IS A SLIDER THAT CAN SLIDE UP AND DOWN IT SAYS HOLD. IT MUST BE DOWN. IF IT'S UP THEN IT'S LOCKED.
    Sep 28, 2008 | RCA OPAL M4001 MP3 Player
    Keys locked.
    The user's manual is available from RCA's website - it will show you the location of the lock switch.
    Jul 03, 2008 | RCA OPAL M4001 MP3 Player
    RCA Opal
    OK - just hold the Hold -> switch
    Jun 02, 2008 | RCA OPAL M4001 MP3 Player
    Mp3 player says key locked system shut down
    I had this same problem on another RCA player.. with no instructions manual it was hard to figure out what keys locked meant. Then I noticed a little slider on the side of the player, it has a little icon of a pad lock on it. Once I slid this back, the keys lock problem went away and I was able to listen to my music once again.
    My best guess of what keys locked means.. you don't want you mp3 player to turn on when you put it in your pocket with your keys, so you change the slider to be locked, when your sit down and your keys are pressing against your on button, the mp3 player will shut off... as we all have experienced in frustration.. saving your battery.
    Perhaps RCA should make this slider bright orange so it pops out and does not blend in so much, or they should put it right next to the on button.
    Apr 30, 2008 | RCA OPAL M4001 MP3 Player
    RCA Opal M4002A Need screen
    I have an Opal 2GB mp3 player just like yours and I accidentaly busted the screen on it, so I e-mailed the RCA company, they e-mailed me back telling me that I voided the warranty, and I would have to send it back and pay 55 dollars to get a new one, because they don't sell the individual screens.
    I hope this helps.
    Apr 02, 2008 | RCA OPAL M4001 MP3 Player
    Keys locked on a M4002A RCA opal
    On the side there is a switch try pushing tht DOWN and it might help ......... If it doesn't work I am really sorry ! :)
    Oct 04, 2007 | RCA OPAL M4001 MP3 Player
    RCA OPAL M4001 MP3 Player Logo
    237 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
