Question about Canon imageCLASS MF4150 All-In-One Laser Printer
I cannot support other USB devices when the printer is plugged in
My computer was giving me an error message on my USB devices. I went into Dell Computer troubleshooting and they said try unplugging other devices that might be draining the computer. When I unplugged the printer the other device worked. I still have the keyboard plugged in with no problem. This just started happening. We have enjoyed the printer with no other problems for almost a year. It is so much better than HP, which we have had for years. I wish I had tried a Canon before.
I hope you can solve this problem. The computer says I would need an external USB Device. But I have had this computer for 4 years with no problems of this sort before.
Thanks!
  • paulg78 Nov 08, 2008
    When the printer is turned on, other USB ports no longer work (plugging in a USB device results in error: "USB device not recognized"). When the printer is turned off, other USB ports work. Previously I had a Brother multifunction plugged into the same computer/same port with no problems. I also have a Dell (Dimension 2400 running Windows XP).
    Master:
  • 505 Answers
The driver for the canon printer may have corrupted. Unplug the printer. Uninstalled all existence of the canon printer driver. Restart you computer. Turn on the printer and then plug the USB cable to the computer. The drivers will get installed automatically and your printer will work fine.
Posted on Oct 07, 2008
Power went out... when came back on got the message "error loading operating system"
While at this message remove any USB storage devices plugged into the computer (Cell phones, USB thumb drives, external hard drives) also eject any CDs and Floppies. Turn the computer off and back on. If the issue persists then it is possible that the power failure damaged a physical component of the computer.
Nov 13, 2012 | Lenovo IdeaCentre K210 - 53132BU PC...
USB Port can preform faster error message
This is because you are plugging in a USB 2 device to a standard USB port, or a USB 3 device into a USB 2 port. The computer is just telling you that if you upgrade the hardware, the device will work faster. Its more of an information message than an error. Your device should still function fine.
Jun 28, 2012 | Dell XPS M1530 Laptop
Anytime I plug something in to the USB port it give a error message that states, Power Surge on the USB port. What can I do to fix this?
The USB device could be drawing more current than the USB port can supply or the USB port may be faulty.
Get a powered USB hub and plug it into your computer's USB port and then plug the USB devices into the powered USB hub.
Aug 16, 2009 | Dell Dimension 3000 PC Desktop
I have bought a new Lexmark x5650 Printer. The setup all went fine but everytime i boot my PC running Windows XP the screen just hangs. When you take the USB cable out of the Printer the PC carries on...
Issue: Computer will not boot with the device connected via USB to the PC
Solution: Disable USB Emulation (legacy support) in the computer BIOS
Turning off USB Emulation (legacy support) in the computer's BIOS
The following steps are for Dell computers. If this issue is occurring on another brand computer, the process of entering the computer's BIOS may be different. Additionally, the steps to make changes may differ as well. Refer to the computer's documentation to verify the appropriate steps to disable USB Emulation.
For Dell computers, perform the following steps:
While rebooting the computer, press the <F2> key to enter the System Setup (BIOS).
Press the Down Arrow <?!> key repeatedly until 'Integrated Devices' is highlighted.
Press <Enter> and another window appears.
Press the Down Arrow <?!> key repeatedly until 'USB Emulation' is highlighted.
Press the Plus <+> key to change the value to 'OFF'.
Press the <Esc> key to exit this window.
Press the <Esc> key again to exit the System Setup (BIOS).
When the message "Do You Want to Save Changes And Exit" appears, press the <Enter> key indicating Yes to save changes. The system will reboot.
Jul 21, 2009 | Lexmark X5650 All-in-One InkJet Printer
Dell printer power button flashes
no the printer is perfect , but many times this error occurs after changing the cartridges.
first remove all the external connections from the printer.OFF the printer remove the power plug.hold for a minute.then plug the power cord and then ON the printer ,connect the printer to the computer by USB wire as regular.and then check by giving printouts.if it still shows the same error.
then try this
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
thanks.
Oct 23, 2008 | Dell 924 All-in-One InkJet Printer
Printer Not Responding
check the device manager for any errors
delete the printer from the device manager and reboot your pc with the printer plugged in
Jan 01, 2008 | Dell P1500 Laser Printer
Windows XP: Blue Screen of Death
Hi are you connecting the usb devices b4 or after windows has started? what version of windows r u running?
Do the usb devices come with their own driversand software?
Dec 18, 2007 | Dell INSPIRON 6000 CENTRINO...
Can't install compaqA1000 all in one
first you unplug the usb cable restart your system and then install the drive software first and then connect the usb cable to the sytem and make sure ther is no other device in your device manager which is showing yellow exclamation mark if it is thre remove that. you can go to device manager by reight click on my computer go to properties and the hardware then device manager tab.
Sep 22, 2007 | Compaq A1000 InkJet Printer
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
57 people viewed this question
old marine
old marine
