Question about Fujitsu AMILO M-6500 Notebook
Power problems My laptop doesn't want to switch on.  It almost seems like the battery is flat, but it is connected to the ac adapter and still doesn't work.
    Problem Solver:
  • 7 Answers
If you have a spare ac adapter, try that just to check if it's the ac adapter.
When you power it on, are there any lights on the notebook?
If there are lights, it is indicating that the computer is receiving power but is not able to go through POST ( power on self test ) and normally it's the mainboard that has the problem.
Either way, if there's no lights, it is also the mainboard that is the main cause.
The notebook will have to be sent in for repairs or just replace the motherboard.
Posted on Oct 07, 2008
Dell latitude 610 AC adapter issue or battery pack issue or both?
It could possibly be the power jack that is inside the computer. This item is typically soldered onto the motherboard and it is what your ac adapter plugs into.
Dec 21, 2007 | Twinhead SlimNote N12PI Notebook PC
There's seems to be a short where the AC adapter goes into the Laptop. Loose parts in that area of the Laptop where the adapter goes in. It won't turn on. Maybe it's the battery.
Unfortunately, this is a frequent issue with laptops. Being moved around frequently can cause the AC Adapter to pull at the DC Jack on the laptop. If it is loose, it can mean there is a broken connection within the laptop. What you can try is powering the laptop on with it plugged in and the battery removed. If that doesn't work, I'd recommend going to your local Best Buy and picking up a universal AC Adapter. If that doesn't work, you can always return it, even if opened.
Aug 27, 2011 | Acer Aspire 5735 Notebook
My AC adapter suddenly can't seems to be able to charge my battery. Please kindly advise
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 08, 2011 | Compaq Presario CQ40 Series Laptop Charger...
I was using my laptop and it automatically powered down. I thought the battery was flat so plugged into the mains. When I switch on button nothing happens, there are no lights on. Green light on AC...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter may be faulty and need replacement.
Or, unfortunately, your motherboard could be faulty.
Hope this helps.
Mar 18, 2011 | Computers & Internet
Power problem
Here are some ideas you can try when troubleshooting power issues with a laptop:
1. Plug the laptop into AC power.
2. Take out the battery.
3. Try a different outlet.
4. Look for the light that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, its possible you have a bad DC jack or the AC adapter needs to be replaced.
5. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on then you can be sure you have a bad DC jack or a bad AC adapter.
7. Replace the switch board and/or the flex flat cable that runs from the switch board to the mainboard.
8. If your laptop has another button that turns it on, such as an internet button, try that button instead of the normal power button.
Hope one of these ideas helps.
Thanks for using FixYa.
Mar 03, 2011 | Computers & Internet
Ac adapter does not connect to battery
You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
2. Try removing your battery and using the ac adapter. If this works the battery is bad.
3. Try a new ac adapter.
4. Power supply is bad
Jun 05, 2009 | Dell Inspiron E1505 Notebook
Laptop wont boot and the battery and power lights flash
a simple power cycle might work. Take out the battery but keep the ac power connected. hold the poewr button down for 1 minute. then hit the power button again and it should poewr back up. If this doesn' t work. iyou said hte battery light flashes so the problem isnt the battery..the problem might be hte ac power adapter..if you have a warranty this would be a good time to call them. Try the power cycle first though this fixes the problems lots of the time
Apr 15, 2009 | HP Pavilion dv1000 Notebook
No power. Adapter light flashes when connected to laptop
thanks for using fixya!!
Please do and observe the following:
1. Uninstall the battery pack.
2. Then, connect the AC adapter, we will try to use the power coming from the AC, then turn on your laptop.
3. Observe what will happen.
4. If still doesn't work, install again the battery, then connect the AC adapter, check if its going to work.
5. If not, perhaps you have a problem neither with the battery or the AC adapter.
I suggest that you bring your laptop to a service center. Good luck!
pls rate me positively! thanks!
Mar 30, 2009 | Acer Aspire 3680 Laptop
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Fujitsu AMILO M-6500 Notebook Logo
85 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
