Question about ATI All-in-Wonder 2006 PCI Express , (256MB) (256 MB) PCI Express Graphic Card
Need install cd for all-in-wonder in windows 95
Where can i buy the cd or get the programming i need?
  • 39 Answers
Http://ati.amd.com/support/driver.html try thiss websight and make shure your spacific on what brand of all in wonder you have
Posted on Oct 07, 2008
I own the DK Multimedia "My Amazing Human Body" CD, version for use with Windows 95. I am unable to use it with my Windows XP operating system. I understand that you might offer an upgrade...
In your case..the fix is to run the program in compatibility with windows 95..
Insert the disk ..and after that if it let's you install it is great ..Install it ..and after that click on the icon (right ) choose compatibility ..and in there tick the case that says "run this program in compatibility mode for : " and choose windows 95 ..
If it do not want to install it at all ..repeat the same thing with the execution icon on the disk ..
Insert the disk ..than in my computer folder..locate the cd icon ...click right on it ..select compatibility ..than tick same case...to run it as windows 95..and will work ..
In case the feature is not available cause the program is on disk and can not accept properties changes...click right on the icon of the cd ....choose explore... and it will reveal all that it has inside..
Copy all files in another folder on your hard disk ..in a location of your choice ..Than the properties will be able to be changed..and repeat the operation I says ..Locate the executable icon ...click right /properties//compatibility ..and select to run in compatibility with windows 95 ..and there will be no more issues..
Jul 25, 2011 | Global Software Publishing My Amazing...
Circle of Blood won't load because it claims there is not enough space on drive c. This happens on 2 computers which have lots of available space. Both computers are running Windows 7. Circle of Blood is a...
Try running in compatibility mode for Windows 95.
1. Right click on the program's shortcut, .exe file, or installation program.
2. Click on Properties.
3. Click on the Compatibility tab.
4. Check "Run this program in compatibility mode for:"
5. Select Windows 95 or higher OS
Feb 17, 2011 | Virgin Interactive Circle of Blood
I'm trying to install CD Label Maker (Data Becker)and can't install to windows 7 (64 bit). Is there an upgrade availabe? Installation CD is for Windows 95/98
Often old programs will install if you go to the CD and make install.exe or start.exe "run as administrator".
Some times you also then have to run the program, after it is installed, in compatibility mode. Again, right click on the program icon, select the compatibility tab, select an old OS like XP or what ever the program used to run in.
Aug 22, 2010 | Computers & Internet
I have a new Windows 7 ultimate. I have the cd Multimedia navigator for Windows 95/98 Ver 1.0. Is it compatible or should I download a new version?
It's not possible to install windows 95/98 version on windows 7 platform. Well, Some programs can be installed using the "compatible mode" from the program's setup properties, but this feature is available only for windows xp and vista on windows 7. I've tried this trick with many applications but never successful. I hope you understand.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Computers & Internet
My Great Brain Robbery is old and says it works with Windows 95, Windows 3.1 & MacIntosh. I have Windows XP and can't seem to get it to setup. Any ideas?
1. Create a shortcut on the desktop for the setup/install program on the CD. 2. Right click in the shortcut you have created and select properties then click on the compatibility TAB at the top of the dialogue box. Tick the [Run this program in compatibility mode for] box and select windows 95. Then click [OK]. 3. Double click the Shortcut you just created and the program will install. 4. After it has finished installing find the shortcut it has created for the game and repeat step 2 for this new shortcut. It should now run in windows 95 mode.
Jan 09, 2010 | Davidson Pre-Algebra Math Blaster Mystery...
How to upgrade win 95 to winxp without removing files installed
A computer running Windows 95 WILL NOT RUN Windows XP in most cases. Post all of your hardware details and we can explore that further.
Most programs that run on Windows 95 WILL NOT RUN under Windows XP easily. There are some compatibility things you can try for each one, but most simply will crash, and some will seem to work for a while then crash at inopportune moments.
What you should do is buy an newer computer with Windows XP, remove your current hard drive, and put your current hard drive as a second drive in the new computer. You will have access to your documents, but your programs will not run.
Mar 14, 2009 | Intel Pentium III, 800 MHz...
I need to install C5000 multipass program but do not have the cd.
The original CD wouldn't do you any good. This printer came out when Windows 95 was the current OS. There are no drivers available for this model for Windows 2000, Windows XP or Windows Vista (and there never were Mac drivers available). If you are using Windows 95, 98 or Me, you can download the drivers here.
If the unit is still printing properly, you may want to use it as a fax machine (only). But I would recommend buying a new printer. The current printers print much faster, with much better quality, and for very reasonable prices (starting at about $50).
Jul 27, 2008 | Canon Office Equipment & Supplies
Need assistance
With Windows 95, you can reinstall th operating system without affecting your data or programs. If you have your original install cd, use this to reinstall the operating system
Aido
Mar 03, 2008 | IBM eserver xSeries 360 8686
ATI All-in-Wonder 2006 PCI Express , (256MB) (256 MB) PCI Express Graphic Card Logo
67 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
