Question about Car Audio & Video
Radio stopped working on my Kenwwod cassette player?
All connections and fuses are good and the cassette player still works but the radio stopped working is there any suggestion?
    Problem Solver:
  • 13 Answers
Are you positive it has nothing to do with the antenna? make sure the connection at the antenna itself is good if you havent already, other then that it sounds like your radio function might be done for
Posted on Oct 07, 2008
Rca bass reflex radio the disc player and Cassette will not work
If can open it up and chek if the disc player and cassette have internal fuses or power connectors are not connected or power supply faulty.
Jan 11, 2018 | RCA Audio Players & Recorders
Fuses when to know time to replace
If the radio still plays then the cassette part of radio is no good
May 25, 2014 | 2001 Ford Windstar
The CD and cassette players do not work.
pull the radio assembly out check to make sure that all your wiring is connected to the radio securly
Feb 10, 2013 | 2006 Dodge Grand Caravan
Where can I find the fuses for the radio? The CD player stopped
the cd player and radio should be on the same system or as a whole, it should all be not working, there may have been a short inside the cd player, check all the fuses in the fuse box look for 10amp and 15 amps usually. being a newer car it is odd. you may need to take it in to toyota for a diagnostic check. good thing about the electrics in cars these days is their computers tell you everything.
Jun 22, 2010 | 2003 Toyota Camry
Car radio stopped working but cassette deck still works
Possible causes:
Stuck or broken button on button panel,
Bad voltage regulator or power section for tuner section,
Bad tuner module,
Bad solder connection on board,
Memory lead for radio not connected or has bad fuse.
Jun 21, 2010 | Car Audio & Video
My car stereo stopped working. No light display. The display light went out first. The following year the radio, CD and cassette player stopped working.
Check radio fuse at the fuse block. OR if possible determine if you have
12 volts going to the radio. If so i would say the unit is toast.
These days it's hard to fix something for cheaper than it is to buy new.
Aug 08, 2009 | Car Audio & Video
Sharp wf 940 portable cassette / radio player
inside radio there is relay near power supply. change it and then radio will work. or clean it.
Mar 01, 2008 | Sharp CD-BA2600 CD Shelf System
Cassette player not working
Cassette players usually have a little rubber band that connects the motor to the spindles. If everything else is fine, I would suggest seeing if it slipped off somehow (or got cracked and snapped)
May 28, 2007 | RCA RCD150 Radio/Cassette/CD Boombox
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
