Question about Samsung HL-R7178W 71" HDTV
On my hls5679w the tv won't turn on and the lights all flash
  • 2 more comments
  • hammers37 Nov 27, 2008
    hello, i have the same mproblem with my samsung hls5687w. it intermittently turns fans on and right back off again. all three leds flash on power button and nothing more happens. i contacted samsung today and they suggest replacing the bulb. i had to inform them it is led and has no bulb! alot of help there! i bought this to get rid of lamp and color wheel issues i have had in past with my last 2 samsungs and now i am not sure what to do. I have heard of capacitor issues on some board on these models but cant seem to find any more info to help me on this matter. thank you
    hello ,i posted a problem with my samsung tv not turning on and all led on button flashing. i posted wrong model number as mine is a samsung hls5679w. any help would be appreciated . thank you
  • jr9682 Dec 09, 2008
    I have this two year old Samsung HL-S5679W model, the whole screen just turn red then the picture completely disappear. Now the timer, led, and stand by temp blink at the same time...still no picture. Can anyone help. I have a Samsung tech. asking for $400.00 and up to fix it and he need to bring the tv to his shop to repair in which he charge $65.00 for diagnostic.
  • Astros2020 Mar 28, 2009
    Please help: I have a Samsung HLS5679W model 52" TV. Recently, when I turn the power on in the morning, it starts blinking all the three lights, then shuts off completely after about 5 minutes. When I turn off and on the power, it seems to work, similar to rebooting your PC. But, now it completely shut off. I can't turn it on. Can anyone help. I saw above from Solution 2, it could be a power supply issue, which is helpful. That gives me a good clue. Can anyone give me a suggestion, if encountered similar problem with this TV. I will v. much appreciate.
    Zodiac
HLS5679W has power supply issues. Two capacitors need to be replaced as Samsung put in units of the wrong voltage...
CM860 and CS860 need to be at least 2000mfd/25vdc radial (both leads come from one end) electrolytic capacitors. It is recommended to have a service tech do this you'll need to pull the power supply out of the set. Parts are cheap (Radio Shack for about $2.99 or so each) but you must be able to solder to replace...
Posted on Dec 11, 2008
    Problem Solver:
Change all 1000uf 25v and 1500uf 10v caps on power supply board.
Posted on Feb 19, 2009
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Visio light on front flashes on and off tv won't come on
Unplug your TV and then plug it back in, let it flash on and off without doing anything for 5 minutes or so and then turn it on. It does it once amonth or so for some reason.
Nov 24, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Samsung HL-R7178W 71" HDTV Logo
618 people viewed this question
Henry  Thomas
Henry Thomas
