Removing cover from compaq evo
I cannot find a way to remove this cover. I have been in the Bios and the lock is off and the senser disabled, any help please.
  • cherith Oct 07, 2008
    serial number H226 JYDZ 0772
  • Indrajit Roy
    Indrajit Roy May 11, 2010
    please provide with the exact model no.
    Master:
  • 505 Answers
Need to clarify the cover you are talking about
Posted on Nov 14, 2008
Replacing bios battery in evo n410c laptop
Dissemble the laptop and find bios battery. It is smaller than desktop bios battery. Usually covered by plastic wrap. Remove it and replace with new one. Observe the polarity of battery carefully.
Regards
Jan 25, 2011 | Compaq Evo N410C Notebook
I do not have a security key to unlock the case. I have removed the two screws in the lower right corner of the back but still cannot remove the case. I need to replace the cd rom
Those two screws should have (on a Tower Model) made it so the lock will be unable to hold the case in place.
If you know the BIOS Password you may be able to disable the lock from within the BIOS.
I do not have one of these computers to perform trial and error on at this time, but If I see one I'll check back and reply to my solution.
Best of luck!
Jan 09, 2011 | Compaq Evo D500 PC Desktop
How can i clear the bios pasword compaq evo D31MP.2.4 MS-6541 Ver 1.0
remove the cpu cover look for three pin near the cmos remove the jumber connect it with the pin which is free and restart in some motherboard the cpu wont start dont panic remove the jumper and replace it in earlear position and restart this clear the bios password
Oct 13, 2010 | Compaq Evo D310M 845G P4 Motherboard
Where is the bios battery located on a compaq evo 600c
This is HP Support, and the download page for the Compaq Evo N600C Maintenance and Service Guide. (Service Manual)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=316673
Scroll down to the heading - Service and Maintenance Information.
Left click on the file name underneath.
Compaq Evo Notebook N610C and Evo N600C Series Maintenance and Service Guide. (25 Jul 2007)
It may take a few seconds before you see the first page of this PDF file. Let it download all the way before looking through it.
Go to Page 104: Disk Cell RTC Battery.
1) Remove the AC adapter (Charger) if plugged in, remove the Battery.
2) Open the Mini PCI Compartment Cover.
[ Located on the bottom of the notebook. Notebook bottom side facing up, front facing forward towards you. The Mini PCI Compartment Cover is to the immediate right of the Battery Release Latch ]
3) The CR1220 disk shaped battery is right there in a holder. (A type of watch battery also) When reinstalling make sure the Positive ( + ) is up.
The Harddrive compartment is up towards the right corner. Located under the Intake Air Duct grille opening.
No where near the RTC {Real Time Clock} battery.
Apr 03, 2010 | Compaq EVO 600C Notebook
Give me password for compaq evo n600c
You can remove your bios password by reseting your CMOS battery or jamper. You need to open your notebook remove first the battery and all screw at the back of your notebook. You can see there a CMOS battery together with the CMOS jamper. Just read it you can read CLRSCR which means clear cmos, just pull it with in 10 seconds and insert it back. Now you are done to reset bios.
Mar 03, 2010 | HP Compaq Evo Notebook N600c
How to open the evo 500 compact black box
Hi maybi,
The evo's have two senarios that you may be facing.
First is Smark Cover locking. If you enable the Smart Cover Lock and cannot enter your password to disable the lock, you will need a Smart Cover FailSafe Key to open the computer cover.
You will need the key in any of the following circumstances:
Power outage
Startup failure
PC component (for example, processor or power supply) failure
Forgotten password,
If you don't have the Key, To obtain a FailSafe Key:
Contact an HP reseller or service provider.
Refer to the HP's Web site (www.HP.com) for ordering
information.
Call the appropriate number listed in the warranty.
To open the computer cover:
1. Turn off the computer and any external devices.
2. Disconnect the power cord from the power outlet, and disconnect
3. Using the Smart Cover FailSafe Key, remove the two
tamper-proof screws that secure the Smart Cover Lock to the
chassis.
4. Remove the Smart Cover Lock.
To reattach the Smart Cover Lock, secure the lock in place with the
tamper-proof screws
Or the non- Smart Cover Case:
1. åWARNING: Before removing the computer cover, ensure that the
computer is turned off and that the power cord is disconnected from the
electrical outlet.
2. Turn off the computer and any external devices.
3. Disconnect the power cord from the power outlet, and disconnect
4. Press in the button on each side of the front bezel to release the
quick release cover latches.
5. As you slide the computer cover forward, release the buttons and
allow them to return to the original position, then lift the cover up
and off the unit.
✎ To replace the cover, reverse this procedure.
f7b910a.jpg Good Luck,
Mark
Oct 16, 2009 | Compaq EVO 500 DT/MT S478 P4 Motherboard...
I found my compaq evo n410c notebook after ages but now when i swtich it on it asks for a power-on password but i have no clue what it is
this varies from laptop to laptop, on some laptops you can remove the bios password by removing the 3 volt memory battery inside, some laptops may have a switch inside to remove the password.
In most cases you will have to take the laptop apart to get rid of the password.
if you enter the password wrong 3 times you may get a system disabled xxxxx number message, a hp service center will be able to unlock the laptop for you.
Sep 10, 2009 | HP Compaq Evo n410c (470042993) PC...
Bios password n610c
Try this: -
Remove your Laptop Li-ion battery module.
Then remove the RTC battery for at least 15min.
Replace RTC, and boot the computer ONLY with the AC-Adapter.
Enter the BIOS and set to boot from USB
Feb 13, 2009 | Compaq Evo N610C Notebook
How to reset BIOS password for Compaq EVO N160 notebook
Do the following steps -
- Remove the laptop battery - Remove the CMOS battery - Leave it for idle for around 15 minutes - Put the CMOS battery in - Boot the laptop  with AC power - Then put the laptop battery in.
 - The BIOS pwd would have been reset now
- For troubleshotting the battery - Go into BIOS and run the Battery Caliberation tool
Hope this helps. Thanks, AK
Oct 27, 2008 | Compaq Evo N610C Notebook
Clear power on password
Removing the Time of Year battery will clear the BIOS password. It is located on the underside of the n610c behind the panel covered by the Microsoft COA label. A small phillips screwdriver is required to remove the two screws on the panel. Carefully lift the BR1225 battery with a small flat blade screw driver.
After 10 minutes re-insert the battery. The BIOS Password should now be cleared, as well as other BIOS settings, the time and date.
Sep 09, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
376 people viewed this question
David Payne
David Payne
