Question about Janome Memory Craft 10000
When sewing the back of the stick is all gathered / notted / bulk of thread and the thread sometimes gets court around the bobbin. Also the thread the goes through the tension before being threaded into the needle continually breaks off. The machines is a Janome MyStle36, it isn't in the list
    Sergeant:
    Champion:
  • 240 Answers
It sounds as if either it is incorrectly threaded, the upper tension is too loose(try no 4)the needle is in the wrong way around(flat side to back if it opens at the front) or that the bobbin area is jammed. Check all of the above and tell me if it helps.
Posted on Jun 11, 2009
How do I wind the bobbin?
There are several ways. On most machines you put the empty bobbin on the spine over the bulk of the machine on the right hand side. Twist some threads around the bobbin to get started, then put the thread through the thread loop above the shuttle area on your left side. That keeps the tread tension right. There is a gear the clicks into the bobbin. You push that closed. You will have to release the clutch by turning the large wheel on your right hand side. Not hard to find and it usually is hand size. It is the one that goes around and around when you are sewing. Grasp it firmly and turn the top toward you. This will prevent the needle from going up and down when the thread is pulled onto the bobbin. Don't forget to tighten the large "wheel" when you are done.
Feb 24, 2015 | Sewing Machines
Why does thread gather in bobbin area and jam machine
Completely unthread the top and bobbin threads. Clean any lint build up out of the bobbin race assembly using the little brush and some canned air. Check that the needle is inserted correctly...with the flat side towards the back. Then carefully rethread the top and the bobbin threads. Make sure the bobbin is inserted correctly...if it's backwards the machine won't sew properly.
Jun 30, 2014 | Brother PE770 Computerized Sewing Machine
Thread Tension
Are you using a plastic bobbin? I had that problem using plastic bobbins, Switched to metal bobbins and it solved that problem.
Also check to see if your bobbin's thread is wound tightly around it. If you can 'squeeze' the wound thread and it feels like it's not firm, the bobbin might need to be rewound.
Jun 06, 2013 | Singer 3116 Simple
Upper thread getting caught on bobbin spool
Has your machine worked before? Check that it is the correct bobbin and bobbin case. Although,if it is the spindle that is sticking out through the bobbin case, that is the shuttle. Perhaps the shuttle is not seated correctly.
Otherwise, it would probably be good to take it for service.
Jan 06, 2018 | Brother Sewing Machines
Thread is gathering under cloth
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
May 05, 2011 | Olde Thompson PWZ500
Bernina Virtuoso 150 - all of a sudden my machine is dropping stitches and the bobbin thread is bunching up. It also most feels like my machine is trying to do a gather stitch. I changed the needle and...
Mar 17, 2011 | Bernina Virtuosa 150
When im sewing my bottom stitch looks good but my top stitch is real loose and sometimes my bottom thread gets pulled up. i have played with the tension but dont help
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 24, 2011 | Brother CS-6000
I have two problems the first is that as i sew sometimes the fabric on the back side gets stuck and there are many pieces of thread coming up from the bobbin and get stuck the second question is everytime...
Feb 22, 2011 | Necchi 6011
What do i do if the bobbin keep sticking it dont want to sew i did every thing i can the upper part is sewing but the bobbin is making a mess
Feb 19, 2011 | Brother LS-2220 Mechanical Sewing Machine
MY MACHINE IS GATHERING UNDERNEATH AND
the teeth of your sewing machine was lowerd thats why if you stich did'nt go forward, adjust it afward, to adjust open the plate and thight the small bolt.
Mar 31, 2010 | Husqvarna Huskylock Computerized 905
Sewing Machines Logo
91 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
