Tevion T2195 wrong colours
Colour got funny strange colours how to degauss
  • Inno Laur May 11, 2010
    Is it in a circular pattern or just blotches all over the place?
Thank you for your response, yes there are blotches of strange colours around the screen.
thanks
sonicfly
Posted on Oct 07, 2008
Monitor colour is ok in the middle circle and on right side it seems to loose the red colour and on the left it seems the green colour is missing.
The CRT has likely become magnetized. On the monitor's main menu there is a "degauss" option. It is the option depicting a horseshoe magnet. Select that option to degauss the CRT, and the color distortion should clear up. If it improves but does not clear up entirely, degauss the CRT again. Is the monitor situated near a magnet (such as a speaker, a subwoofer, or some other source of magnetic field)? If so, either move the monitor away from the magnetic field source or move the magnetic field source away from the monitor, then degauss the CRT by selecting that option from the main menu on the monitor. Was the monitor dropped? If so, a series of electromagnets at the back of the CRT (called the "blue lateral") may have come loose. This is somewhat challenging to align and is best handled by a technician.
Jul 02, 2011 | Daewoo 719BF 17 in.CRT Conventional...
Hitachi C21 model.The colours on screen have got scrambled.
It sounds like something has left a strong magnetic field on the face of the picture tube, and that's causing the colour distortion. The electron beams from the tube's colour guns are hitting the wrong spots on the face. There is a degaussing circuit in the TV that tries to neutralise such fields every time the set turns on. Sometimes electrical equipment (particularly motorised appliances like a vacuum sweeper) operating too close to the TV can leave a field too strong for the degaussing circuit to cope with. Or a failed part in the circuit may have made it inoperative.
A hand-held degaussing coil can be used to remove the field. You can purchase one online, or call a TV service technician. It used to be a standard tool to carry.
Another possibility is that the tube has been damaged. There is a very thin metal mesh screen called the shadow mask behind the face of the tube. If this mask has been warped by a strong magnetic field or a mechanical shock (if the set was dropped, for instance), you will see the same colour distortion. In this case, however, there is no repair other than tube replacement. And that is likely to cost more than a new set with parts and labour.
Jul 26, 2010 | Hitachi C21-F200 21" TV
Losing water from the resevoir no leaks or cracks visable on the resevoir water a funny colour.
water weill be a funny colour its the antifreeze in it ?? if the colour is not the same as the antifreeze then check it out because antifreeze will go a funny colour when the combustion gases from the engine mixes with it ,in other words you may have a head gasket problem
Jun 12, 2010 | 2002 Jaguar X-Type
Colour change on tevion tv
is all the screen the same colour or is it patchy. It could be the degausing cerquet (if patchy). Or maybe just to be degaused with a degausing coil.
Jun 01, 2010 | Televison & Video
Television picture colour
This is because you have something emitting an electric magnetic pulse close to the TV. Like a large unshielded speaker or large Battery. First thing you need to do is move anything near the TV away and see if that correct the issue. Next would be to degauss the TV. Unfortunately the TV probably does not have a built in degausser.
A degausser is an electro magnet in a circle. you plug it in and run it around the surface of the TV.
Mar 20, 2009 | Beko 324250WN 28" TV
My tv don't work
Inside the set is a part, usually a thermistor that kicks in the degaussing coil. That is the part that will clear up any stray magnetic field interference. These parts can fail over time. It sound to me like the thermistor has failed and the degaussing process no longer occurs. This is a $10 part and is usually stocked by any TV service shop. Call around and explain that you need this part replaced to get the least expensive service for this set.
Dan
Feb 17, 2009 | Sanyo DS27800 27" TV
Colour
The CRT shadow-mask may no longer be degaussing, or the shadow-mask in the CRT is defective.
In or near to the power supply there is a thermoresistor that controls the degausser coils. When the set is turned on this thermoresistor gives a momentary high AC current to the degausser coil with a rapid decay for slightly over a period of about 200 ms or 1/5th of a second.
If this thermoresitor is defective, it will have to be changed to resore the degausser coil to work again.
On rare occasions I have had a bad degausser coil that had to be changed. I have also had the shadow-mask in the CRT become defective. The fix for a bad shadow-mask is to change the CRT. This is not feasible for this TV set!
You should get an experienced TV service tech to fix this for you.
Jerry G.
Nov 05, 2007 | Sanyo DS32224 TV
Strange colours on television
What do you mean by 'strange colors'? Is it colour patches at the corners and edges of the picture? If that is the case, it is asimple case of Degaussing or Demagnetisation. You need to do nothing, The internal degaussing circuits will sort out the problem over the next 2-3 days. Just make sure you have not placed any equipment with magnets or any magnetic source near your Tv (Speakers, Boob Boxes, Walkie Talkies, etc.
Oct 09, 2007 | Televison & Video
Television colour
your problem is simple it is called colour patch. it is basically due to change in direction or you must have shifted or tilted. it might be due to magnetic effect like spkr,telephone near by it.just remove from that location. put of the set for 15 minutes &put it on .problem will get clear. ask tv tech. to degauss it by dega.coil.it hardly 1 second job. regards
Sep 12, 2007 | Televison & Video
Televison & Video Logo
336 people viewed this question
Top Televison & Video Experts
