My laptop was working fine and then the ac adapter stopped charging, so i bought a brand new one. My laptop still does not turn on or give any response to a charge, even when i take the battery out to see if the battery is dead. My laptop is only a year old and i would really love to know what is wrong with it.
    Genius:
  • 1,124 Answers
The common causes are:
Bad Power adaptor
Bad charge connector (on laptop motherboard)
Bad Battery
If you already have replaced your power adaptor (ac), try replacing the battery and see if the new battery start to charging or keep the charge, if not you will have to replace the charge connector located on your motherboard.
Posted on Oct 07, 2008
    Master:
  • 505 Answers
It is a problem with connection. You need to check with your hardware vendor
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
Advent modena m200 will not turn on or charge.
Connect the AC power adapter to the laptop and confirm that the AC power indicator is on (I wish you stated the brand of laptop). If the AC power indicator is not on, try and get a working AC power adapter for your laptop and connect it to your laptop.
With the AC power adapter connected, you can power on your laptop. If the laptop powers on from the OS you can see if the Battery is charging or not.
If the laptop does not power with the AC power adapter connected, then the power port of the laptop is bad.
However, if all these are okay and the battery still does not charge, the battery is faulty and will need to be replaced.
May 15, 2012 | Advent Computers & Internet
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
My laptop charger light is blinking. i just got a brand new ac adapter. didn't use it for 2 weeks. is it just charging or is the ac adapter defective.
Hi
It means that the charge is not compatible with your laptop model or AC charger is faulty. I suggest you return it to the shops for free replacement and it would be better to bring with you your laptop. To give more precise AC adapter for your computer. Regards
Jun 13, 2011 | HP Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Will Not charge with brand new a/ power cord it will at times power on if moved the right way but quickly powers off if moved the port inside looks to be fine But I hear there is a pin type thing inside...
The problem is with the AC adapter itself and is a very common problem with Dell AC adapters. My suggestion would be to get an aftermarket AC adapter that can be purchased on eBay as the Dell adapter is around 100.00. You can pick up an aftermarket one on eBay for around 20.00. The problem is a resistor inside the AC adapter that senses when a Dell branded adapter is inserted. What happens is that the resistor will get damaged and since it doesn't recognize the charger as a Dell branded one anymore it won't charge. However it will still run the laptop as long as it's connected. A lot of aftermarket AC adapters bypass this function and work perfectly fine.
May 29, 2010 | Dell (04U621) for Latitude D600, Inspiron...
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Battery doesn't stay charged
The problem is with the battery. All Lithium batteries last for around 1000 charges or so. Since the laptop is 2-years old the battery needs to be replaced.
I Hope this solves your problem. Kindly Accept my solution.
Regards, Arjun
Apr 01, 2009 | HP Compaq Presario C306US Notebook
Compaq EVO N400C PC Notebook Problem brought new battery! fully charged all night! turn laptop on within one second the thing turns off! AC works fine! new battery! old laptop! what can i do, please help?
your laptop should function even without a battery. Remove the battery you just bought and see if only with AC adapter, would your laptop turn on?
If not, then try removing the memory and see using a pencil eraser, clean the contacts of the memory and see if you can power your laptop with only ac
Apr 05, 2008 | Compaq Evo N400C Notebook
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
