Question about Nokia 6820
Front keypad failure
Hi all , i have nokia 6820 with front keypad not working , inner and outer . any help would be appreciated .. thanking you kevin
  • 175 Answers
Hello Kevin try cleaning the contact between the keypad on the flip and the board. And if that doesn't help teh flex will probably need to be replace. Hope that will solve your problem.
Posted on Jun 02, 2006
My Kenmore Elite Oasis HE model # 110.2706 stopped working during the middle of a load and showed an F 50. Tried to unplug it, restart it and tried the clean machine mode. Nothing is working.
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 27, 2010 | Kenmore Elite 45986 Front Load Washer
Keypad lite not working both inner and outer side.please help me?
keypad not working for nokia comunikator 9500. please help me for solution ?
Nov 30, 2009 | Nokia 9500 Communicator
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
Nokia n73 front camera hardware failure
Aug 17, 2009 | Nokia N73 Cellular Phone
Water won't drain and f keeps flashing
Apr 04, 2009 | Kenmore Elite 45986 Front Load Washer
Nokia 6820 upper left side keypad dislodged
Press down, don't be afraid to use force. It will go back in eventually unless you broke a clip off. It should be fine.
Mar 18, 2009 | Nokia 6820
Sears garage door opener, chain adjustment
Loosen the inner nut on the trolley. (That is the lock nut). Then tighten the outer nut on the trolley to increase tension. The outer nut on the trolley is closest to the garage door. The chain tension should be 1/2 inch off the rail at midspan. (The chain is fastened to a threaded bolt on to the trolley. The threaded bolt has an inner and outer nut). Hope this helps.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Nokia 6820 black screen
you have a damaged screen. they generally go black when they have been cracked and the liquid crystal has leaked. the LCD can be replaced, but if it also has a tired battery, it is probably not worth repair. If you want to replace the display,you need the correct tool to remove the screws from the chassis internally, and the new LCD can be purchased from http://cellink.com.au/products/ They have the tools and parts to repair just about any phone. Good luck. A "fixya" rating for my advice would be great :)
Feb 02, 2008 | Nokia 6820
Outer keypad of motorola A630 does not function properly.
take the phone and have the keyboard (Outer) replaced or service.
Jan 24, 2008 | Motorola Mobility A630
Nokia 6820 Logo
83 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
