TV picture vertical drift.
Cold-start, picture OK. Later, picture drifts slowly upwards off screen.
  • 2 more comments
  • ronpate Oct 07, 2008
    I will apply the solution offered.
    Thanks.
    The entry form would not accept my make/model data. Why?
    Anyway, the TV is a Sony Trinitron (not a flat panel...my mistake), Model KV-27S26, made in 1997.
    Thank you for your guidance. Yes, I have the necessary experience: as a design engineer, I've worked in all phases of low-voltage circuit development including PCB design, fabrication, assembly, and testing.
    TV's and high-voltage work have not been my experience.
    I have gotten the service manual and board layouts for the Sony KV27S26 from an internet source.
  • ronpate Oct 09, 2008
    Thank you for your advice. I will begin work on the TV this weekend, so I will get back to you sometime next week or maybe later depending on parts delivery.
    Genius:
  • 1,124 Answers
Give us the brand of your tv.
You will find help here:
http://www.repairfaq.org/sam/tvfaq.htm
Posted on Oct 07, 2008
  • 10,594 Answers
Symptoms shows weak capacitors in deflection circuit.
Please mention model and brand of your TV.
How old is your TV?
Thank you.
  • Shahid Electronics
    Shahid Electronics Oct 07, 2008
    OK, so it is Sony KV-27S26
    Please let me know do you have electronics knowledge and some know-how of solder work like recognize and replacement of electronics parts to provide you further information to resolve it.
    I also want to know do you have service manual of subject TV? because it would be easy for you to locate identified / suspected parts in main board or I need to guide you here by pictures.
    Thank you.
    That's great, being an engineer you have more knowledge then me, please check weak electrolytic capacitors in horizontal and vertical deflection area and power supply of tv. As you know after along run solder joints got some kind of dryness and couldn't make proper connections between PCB and mounted part, so re-soldering such cold solder joints is good idea.
    You have service manual and it is enough to identify parts location, getting part numbers of defective or suspected parts with description etc.
    I hope tv problem will resolve as its not so complicated tv as compare to current models.
    Thank you.
Kenwood problems
do you mean the knob, or it just drifts down in frequency? if the knob drifts down, consult the manual on adjusting the tension on it, if it drifts down in frequency, it needs to be services, there are MANY things that can cause this
Aug 17, 2014 | Radio Communications
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Model 917-372832 Eager-1 5.5 HP . Stopped running . Won't restart. I believe the timing may of moved. How to remove the fly wheel to check key position? The key may have stripped. Hit a rock which may...
Hi, you are correct, the key will be sheered. Remove the top shroud and flywheel nut, then while pulling upwards on the flywheel have someone strike downwards on the crankshaft with a hammer and brass drift. Do not use a steel drift as it will damage the crankshaft. Hope this helps, regards Phil.
Jul 18, 2011 | Craftsman Garden
Touch screen applications at top of screen sometimes disappears then comes back later.(like it has slid up under frame) Almost seems to do this when it's warm.
I would have said recalibrate, and you can still try that, but I suspect the vertical hold transistor is faulty and is allowing drift when it warms up. It will need a new motherboard as the items are throw away at high prices.
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Garmin StreetPilot C330 GPS Receiver
Pic is distorted, wavy and compressed on the bottom half o
This is a problem with the vertical circuit. Most likely one or more capacitors in that circuit have drifted in value enough to effect the picture as you describe. If you can update this with the make and model, I may be able to list the probable parts that need to be checked.
Dan
Apr 08, 2009 | Televison & Video
Satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
Apr 22, 2008 | DISH Network 301 DTV Receiver
Toshiba 3387DB Television
it is due to 60Hz HUM IN POWER SUPPLY. please check for input supply. also check for mains filter capacitor in tv. also check for one diode open in rectifier ckt.
Oct 02, 2007 | Toshiba 3387DB TV
Toshiba 42wh36p
Please define line tearing or line hold drift==Do you mean horiz. or vertically?? Is the problem the same on all sources?? Any change hot to cold?? more diagnostic observation needed.
Aug 05, 2007 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
