Question about Nokia 7390 Cellular Phone
Phone won't turn on properly
So the problem with my phone is when i turn it on the clock appears on the mini screen but nothing is on the main display ... sometimes there'll be stuff on the main display but i can't do anything b/c it's just frozen and if it's not frozen it'll just go to the menu but when i click on something it'll freeze :( i don't think it's the battery .. i think it's the phone..
  • Nokia Master
  • 1,800 Answers
Hi Miss_Pink03
most likely those symptoms appears when the phone Flesx cable is faulty
What is the phone flex cable??
its the electronic stuff that connects the keypad to the Main and Mini Display
u most replace it and its not an easy task though
plz do rate this post
Posted on Oct 07, 2008
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
There is an icon that came up and it looks like the old fashioned film you would put in cameras. Looks like 2 circles with a line underneath. Ever since this popped up when my flip phone is closed the time...
that could be the indicator for "you have voicemail messages waiting" -- It looks like a little tape cassette. Pick up your voicemail and it will go away.
as for the time display on the front screen, check that you have the screen saver enabled - Settings, Mini Display, Screen Saver, Digital Clock (or analog clock if you prefer), then check again to make sure it is set to On.
Jun 09, 2010 | Nokia 6085 Cellular Phone
Want font larger (currently very small) and in white color (current color is blue) when phone is closed (NOKIA 6085)
The only thing you can change is the screen saver for the "mini display" - Settings, Mini Display, Screen Saver, then choose "Digital Clock" - when the screen saver kicks in you'll see the time in nice large numbers.
The mini display is monochrome so you can't change the color.
May 24, 2010 | Nokia 6085 Cellular Phone
The screen is showing display for clock adjustment but none of the touch screen buttons working
this problem is due to loss of connection between main board and lcd unit replace FP-185 flex cable
May 20, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Turn off clock on my phone.
Main Menu> Settings> Display & light settings> Display> Wallpaper> Choose images (this will just disply a small clock at the top) or choose "Use Theme" (this will let you choose what clock sort you want on your wallpaper (do this by choosing "Use Theme"> Save> My Theme> Select Theme> Chose one of the 3 themes))
DO NOT choose "Living World" as this will display a large clock
Hope this helps
Mar 26, 2009 | Samsung U900 Soul Cellular Phone
Main Display
Hi. Have you tried replacing the LCD screen? You can buy one herehttp://www.formymobile.co.uk/proddetail.php?prod=6131lcd and see thedisassembly section of the following file for fitting https://www.yousendit.com/download/Y2o4WGJEY1NxRTFMWEE9PQ
Nov 14, 2008 | Nokia 6131 Cellular Phone
Nokia 7390 main screen blank
Yes, the connector is faulty and need to be changed.
May 16, 2008 | Nokia 7390 Cellular Phone
Nokia phone problem
Can't use Nokia phone. Screen displays this message. "insert Smartchip"
Oct 12, 2007 | T-Mobile NOKIA 3395 Flexible Mini Boom W/...
Nokia 7390 Cellular Phone Logo
73 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
