Question about Brother MFC 7420 All-In-One Laser Printer
BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
MY BROTHER MFC 7420 PRINTS A SOLID VERTICAL LINE ON THE LEFT SIDE OF THE PAGE. ONLY WHEN AUTO FEEDER IS USED..
WHEN COPYING FROM THE GLASS SCANNER COPIES ARE FINE...
CAN YOU PLEASE HELP ME????
  • 1 more comment
  • dklinger553 Oct 15, 2008
    I have exactly the same problem. Don't know what to do!
  • greg58 Feb 07, 2009
    I have a long vertical line which shows up on the right side of each sheet when I scan from the document feeder. How do I fix it?
  • Anonymous Mar 14, 2014
    It would seem the copy from the text won't line up proper on the tag. As well as the ink isn't printing solid on the tag
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Posted on Jan 15, 2009
  • 8chpk
    8chpk May 18, 2014
    Staple damage to the mating white strip above the glass - now what? Can one go to the white strip store for a replacement or use whiteout or what?
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Copies are being printed with a line vertically down the side of the page. Only happens when copying using the hopper.
If it's a thin, sharp line, it's just a blob of ball-point pen ink on the scanner glass. Lift the lid, and you'll see the narrow strip of glass that the scanner uses when you feed a document through the feeder. Clean that with a rag dampened with window cleaner, or, better yet, alcohol. Even a dot of ink too small to see will show as a solid black line on anything you copy, scan, or fax via the doc. feeder.
Don't use so much cleaner that it runs under the glass.
Nov 10, 2010 | Brother MFC 7420 All-In-One Laser Printer
When i am faxing do i put the paper up or down on this thing brother mfc-7420
Either lift the lid lay the paper in print side down, or put it into the document feeder print side up. In either case the top edge of the page should be at your left to appear right-side up at the receiving, but that's a minor point.
Sep 15, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
Sep 17, 2009 | Brother MFC-7220 All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 prints black pages
The drum is defective. The cleaning blade has failed.
Jan 31, 2009 | Brother HL-2040 Laser Printer
SOLID VERTICAL LINE ON AUTO FEEDER COPIES
Hi Sally,
Open the flatbed lid and look on the left side, I believe there is the flatbed glass and another piece of glass to the left, the small strip of glass is the one used for the automatic document feeder. this piece af glass needs to be clean or you will get a line from top to bottom from any type of speck on the glass. hope this helps... if so please mark as FIXYA!!
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
1,337 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
