Question about LG LHT854 Theater System
Help With My Rear Speakers
I dont understand why when I play a dvd my back surround speakers work but when I have the regular tv on I have no sound running through them? Could you tell me why this is and if there is something I can do to fix it? Thank You Amber
  • 1 more comment
  • stacy11885 Dec 28, 2008
    I have the same problem I cant get the rear or the center speakers to work in any mode?
  • jtman7676 Jan 12, 2009
    i cant get my back speakers to work with my lg blueray. it works with the dvd so i know its not the speakers. is it compatible with the blueray?
  • spitzit Jan 18, 2009
    on my lg lht854 home surround sound system i just bought the center or the rear speakers will not work, but when i try the test, it works fine. help!
    New Friend:
  • 3 Answers
Just clicked on sound effect on the lg tv remote it was set to 2.1 changed to 5.1 and the system came alive!!
Posted on Jun 05, 2013
You will need an optical audio cable for the system to work in surround sound with anything other than the DVD. They are not expensive Teh optical cable will run from the TV to the home theatre.
Posted on Sep 10, 2010
You can use da sorround sound for anything....to get that working you first need 2 get an optical cord to connect from your home theater system to your source of connection...then u hit the vsm button on ur remote which is right under the eq....and change dat 2 matrix or plx movie .....u shud have the sorround workin now
Posted on Jan 23, 2009
  • ebuks Mar 29, 2011
    when used with VSM you don't get a real sound; what you get is back ground noise which is not as loud as the front speakers
    Sergeant:
    Champion:
  • 341 Answers
Try to check the settings of your surround amplifier. The decoder might not be able to send audio signal to the rear speakers due to the TV source audio input. You can check the modes available for your type of audio decoding. hope this helps.
Posted on Oct 07, 2008
I was told by a rep from lg that i could only get the rear speakers to work with a dvd only...i just bought this new and a 42" lg4230 lcd so i could have "surround sound on everything...it sucks unless someone can tell what is wrong...any help would be appreciated...i already did the setup and went thru all the speakers but wont work when i want it to.
Posted on Nov 20, 2008
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
I have had the Kenwood VR-407 since 2001. I also have a Mitsubishi projection TV, attached to the receiver. When watching regular cable TV (u-verse), I can not get sound from the rear speakers. I am using...
Most TV stations you watch don't send a surround sound mix so you won't get anything in the back speakers. DVDs generally all have a surround mix which is why it sends to all speakers. What you are experiencing is normal, Bob.
Jan 04, 2011 | Kenwood VR-407 Receiver
Rear Speakers dont work
THe rear speakers are usually for the surround sound experience. What kind of movies do you watch? Usually the action movies have a lot of surround sound, calm movies not so much. And for the music, the same thing applies. Atleast for my system.
Hope this helps.
May 09, 2009 | Televison & Video
I need help hooking up my tv and dvd player to my surround sound
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at swinginflames@gmail.com and i try to help you. hope that works :)
Feb 22, 2009 | Durabrand 5.1 Surround Sound Computer...
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
Sound comes only fron one rear speaker
Did you try switching Speakers A and Speakers B button on the AV receiver?
Jan 10, 2009 | Bose Acoustimass 10 III System
Panasonic Home Theater SC-PT760
This is not a problem, this means that your system is working. Polar Express was recorded in Surround Sound with separate tracks for each speaker channel. In most movies you will find that the rear speakers will only play certain sound effects so that it appears they are coming from behind you (gun shot, train, fireworks). Most of the diaglouge will come through the center channel and music/effects through the front left and right, with bass coming from the subwoofer.
Now, you can still hear more from the rear speakers if you like this enveloping effect, or if you like your music coming from all directions. There are Sound Effects options to have the front and back speakers always playing the front track, there is Dolby Pro Logic II that turns stereo sounds (like many TV shows) automatically into 5.1 Surround Sound, and you can also individually change the volume of each speaker.
These are all explained on page 29 of your owner's manual under Sound Options. If you need specific button to button help, let me kow.
Jun 29, 2008 | Audio Players & Recorders
Surround Sound Not Playing For TV Programs
Greetings jdm12,
I can understand your problem, I have some what of the same issues with my home theater setup when watching events. One of the only suggestions I can make is adjusting the "Dolby Pro Logic II Mode". After reviewing your owners manual it appears you should be able to change the mode by pressing the PL II Mode button found in the lower keypad on your remote. It appears the options you should have are Music - Cinema - Pro Logic - Matrix - Stereo. You may want to try Music or Stereo when watching your events. In Stereo setting it should provide sound out of the front speakers and sub-woofer only. In Music, there are more processing that is done so you could hear more then just the front speakers.
I hope this makes your next your next PPV Party a big hit!
Jon
Go Ahead. Use Us.
Jun 17, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Sorround speakers
surround speakers will only function when the video that is being played is encoded with surround sound. like 5.1. otherwise it will only play in regular stereo mode.
Jan 09, 2007 | Panasonic PT-51G44 51" Rear Projection...
LG LHT854 Theater System Logo
558 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
