Question about Samsung Digimax U-CA 5 Digital Camera
Won't turn on
Hey! I have the Samsung Digimax U-CA5 camera. I got it brand new, 4 months ago. My problem is that it won't turn on. Ive charged the battery many times, and it still doesn't turn on. When i pulg the charger in, the little green light comes on, meaning that it is fully charged.. Ive checked if the battery was in propery and it still won't turn on. Im not sure what to do. Im away from home, so i dont have the warranty, etc. Please help me! lol shayda
  • Anonymous Nov 23, 2007
    i have a samsung digimax u-ca5 that will not turn on even with ac power adapter connected. could it be the on button defective? i have put in another memory card and charged the batteries but it still has no response.
  • gennn Feb 13, 2008
    My camera wont turn on. It was purchased new about 9 months ago. I tryed removing the batterie and memory card but it will not turn on. I tryed to charge it but the green light appears (meaning that it should be fully charged) but it is still dead.
jackboy
  • 2985 Answers
SOURCE: I am have Samsung Digimax S600
Well all the time these item [didgi cams and small electronics of all sort do seem to have a high fail rate. But as I said less than a year - take it back
Posted on May 25, 2007
SOURCE: Samsung Camera mod DIGIMAX S500/Cyber 530
still that happens to me sometimes...this is when you need t o charge your battery over again fully....
Posted on Dec 31, 2007
SOURCE: Samsung digimax D103 10 million pixel camera
This error is due to the lens mechanism being jammed and unable to extended, usually due to dirt or grit getting inside. The motor times out and the camera beeps 3 times before shutting down.
If you are unable to have Samsung fix this under warranty, you can carefully prise the lens out using a feeler gauge while powering the camera on, giving the motor a little help.
Posted on Jul 13, 2008
SOURCE: Samsung Digimax L730 Digital Camera
This problem is usually caused by grit in the mechanics of the lense. To resolve the problem:
1. Ensure the lense itself is clear, removing any visible objects.
2. Try tapping / knocking the camera to dislodge any obstruction.
3. Failing this you can force the mechanics by turning the lense sections - however be careful when attempting this as you may snap the lense if turned too hard or the wrong way.
Words of wisdom from: Malhotra, Manmohan
Posted on Nov 05, 2008
  • 11967 Answers
SOURCE: Hi, my samsung s750 camera won`t turn on, the zoom
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 04, 2009
Why wont my battery charge at all
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2012 | Samsung Digimax L60 Digital Camera
I have 2 batteries but some how i can not charge even i have left them 24 hrs to charge
Digital camera batteries are usually with an external battery charger.
The charger maybe faulty, the charge adapter will have a LED indicator to indicate that it is charging.
Jun 15, 2012 | Samsung Digimax L730 Digital Camera
Camera won't turn on
Yes! the cost to repair would not be practical, this is a systems control board issue.
Mar 12, 2012 | Samsung Digimax A503 Digital Camera
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
Hi! My Nikon S570 model won't turn on. I haven't dropped it or anything and I charged the battery and it was complete. I've had this camera since February 2010. What should I do?? -Monica
i have a nikon s570 that is about 18 months old. (not under warantee anymore) it won't turn on, so we bought a brand new battery, charged it and it still won't turn on. Nothing. no motor noise, no lights, nothing. any ideas? nikon wants us to send it to them for evaluation and fixing....any thoughts?
Jan 15, 2011 | Nikon COOLPIX S570 Digital Camera
Ineed a user manual for a Samsung Digimax U-CA5 Camera
You can download user manual free copy of Samsung Digimax U-CA5 from HERE
Thanks.
Nov 12, 2010 | Cameras
Samsung L703 didital camera wont turn on
For me also same problem No power ON Green LED blinks
Oct 28, 2008 | Samsung Digimax L730 Digital Camera
Will not turn on
Comment by The Fixx, posted on Oct 31, 2007
And here is the solution... Eureka - we have found a cure. Internal memory of 16MB is shot. Buy a memory stick, insert and voila.... The camera is back too life. And apologies to Samsung....This is really an extrodinary little camera.
Aug 30, 2007 | Samsung Digimax 401 Digital Camera
Samsung Digimax U-CA 5 Digital Camera Logo
37 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
