Question about Brother MFC 7420 All-In-One Laser Printer
SOLID VERTICAL LINE ON AUTO FEEDER COPIES
WHEN I MAKE COPIES FROM THE FLATBED THE COPIES ARE CLEAN BUT WHEN I USE THE AUTO FEEDER IT MAKES A SOLID VERTICAL LINE??? PLEASE HELP....
  • SALLY7861 Oct 07, 2008
    THANKS ALOT IT WORKED. YOU ARE THE BEST!!!!!
  • Anonymous Apr 01, 2014
    In order to get rid of the vertical line caused when using the document feeder to make copies
    Novelist:
  • 170 Answers
Hi Sally,
Open the flatbed lid and look on the left side, I believe there is the flatbed glass and another piece of glass to the left, the small strip of glass is the one used for the automatic document feeder. this piece af glass needs to be clean or you will get a line from top to bottom from any type of speck on the glass. hope this helps... if so please mark as FIXYA!!
Posted on Oct 07, 2008
  • Erin O'Donnell
    Erin O'Donnell Nov 30, 2011
    I agree....you ARE the best! Something so simple, and it drove me nuts for SO long! Now I know where to look for solutions :)
  • Susan Gordon Dec 09, 2011
    Thank you. It worked!!!
I have the same problem but cleaning the glass didn't help - what else can I try?
Posted on Jan 09, 2009
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Mar 03, 2014 | HP Officejet Pro L7680 All-In-One Printer
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
Black vertical lines in copies
You need to clean the glass. Open up the feeder and you have a large piece of glass for scanning and to the left a smaller piece of glass that it uses to scan from the feeder. Clean this smaller piece of glass; even the slightest smudge can leave a black streak.
Jun 25, 2009 | HP LaserJet 3030 All-In-One Printer
Vertical line down all copies coming from the top multipage feeder.
Please provide model number......however, if it's a "copier style" if you open the auto feeder, there should be a large contact glass and then a small "****" glass on the side that is used when using the auto feeder -clean this glass thoroughly (clean both while you're at it). If it's just a regular style fax machine, there will just be a small glass under the cover that needs to be cleaned.
Please let me know :)
Apr 21, 2009 | Office Equipment & Supplies
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Dell All in One Printer 962-dark vertical line on photo copies
If you are running your copies through the document feeder then see if the line goes away if you make a copy directly from the glass. If the line goes away then open up the doc feeder assy. by hinging it to the left. Underneath you will find that there is a thin strip of glass that the document passes over when it is scanned. Clean this strip of glass and this should correct your problem. If there is a smudge of dirt or small line, it will come out as a solid verticle line when scanned.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
593 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
