Question about Kenmore 63942 Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Previous posts mentioned that when they pushed the button that they heard a humming noise. When I press the start button there is no noise at all. The light does come on when the dryer door is opened.
  • Anonymous Nov 21, 2008
    light works, no noise no working when i touch the button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Posted on Oct 16, 2008
I have a Kenmore 80 Series dryer. When I push the start button it makes a noise but won't turn on or it turns on for a few seconds and then stops
Did you figure out what the problem was? I have the same problem with my Kenmore dryer.
Thanks
May 17, 2010 | Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
I have a Kenmore 80 series 110.70812990 won't start!
first ceck the door switch,if not thatunplug remove back and check the long white main fuse to your left-mike
Kenmore 80 Series Gas Dryer won't run unless empty
MORE THAN LIKELY YOUR TENSION PULLEY IS SHOT WAS IT MAKING ANY SQUEEKING NOISES
Aug 26, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series electric dryer wont start
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Jul 22, 2009 | Dryers
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
162 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
