Question about RCA HD52W59 HDTV Projection Television
Convergence This is the second time I'm posting this problem. I have an arcing problem at the top and bottom , the center seems fine. Auto convergence does not fix the problem. Manual convergence allows me to "converge" the middle but not the top and bottom. Lots of red and green shadows. We have been dealing with this for months trying to find a happy medium where the picture is okay. NOW we move the t.v. to a new room and suddenly the auto convergence works...perfect picture. BUT it only lasts for a little while before having to auto converge again. What's up? I have no knowledge of t.v.'s and no interest in tearing it apart. Just want to know if it's worth fixing?! Thanks for any insight provided.
  • 905 Answers
You need to have the conversion chips replaced , this is a pretty common repair and i would say it is definately worth the fix, some repair shops will come and fix it within a half hour to an hour depending on the difficulty in taking out the old part and or putting in the new
Posted on Oct 07, 2008
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Pincusion/Convergence Problem
You can find some presets on the display section of the motherboard. You try adjust to fine tune the picture.
Keep a mirror in front of the TV and try adjust the presets slowly with the help of a properly insulated screw driver.
Caution TV venerates very high voltages.
Jul 25, 2009 | Televison & Video
Toshiba rear projection 42h81 convergence problem
In that case the convergence Ic's are defective or "leaking" they must be replaced. these are the TDA's
Jul 09, 2009 | Toshiba 53H71 53 in. Rear Projection...
Alignment issue - PT-47wx49 Panasonic PTV Tubes out of align
your convergence is off. u need to get in service mode to correct this problem. its pretty in depth and time assuming. u need to go to servicemanuals.net and for 15 bucks u can get a service manual. it has every thing u need to fix that tv. i had same problem but i had all 3 colors out of whak. i see alot of people on this forum changing the ic's and resistors to fix convergence problem, (me too)and nothing works. i got this manual and saved me alot of money. its been 3 months since i corrected it and i am still watching it. good luck.
Nov 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Blue color is out of position
sure sounds like convergance problem
http://www.partstore.com/Part/Samsung/
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Older Projection TV Hitachi 50ES1B about 1993?
Convergence amp ic's bad
Jan 07, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi53SDX89B color problem
Blue convergence IC bad...have both IC's changed..insist on
STK394-160E upgrade part # CZ 01341 Hitachi brand.....Original part is STK392-110......Also, check B+ feed resistors next to
convergence amp IC's for burn / damage...after rebuild, press magic focus.......................T.
Dec 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Convergence
Replace both convergence IC's part# STK392-040. Also check for burnt/discolored resistors nearby.
Aug 23, 2007 | Samsung HCL4715W 47" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
