Computer is running on the wrong drive
My computer is running on the H: not the C: drive. The C is the primary drive. How can I get it to run on the C again. I have already tried the F10 function at start up.
  • Bodiddly Oct 07, 2008
    It is not working off C, can fomat to C
  • Bodiddly Oct 19, 2008
    Windows XP, and what are partions?
    Sergeant:
    Champion:
  • 334 Answers
Is it wrking ok off c just shoing h as main then its ok if drive letters are mese dup form formatting it wrong k
Posted on Oct 07, 2008
  • nick helpap
    nick helpap Oct 07, 2008
    what letter os on how many partions u hav eon this hard dirve
My computer is not able to detect hard disk of western digital make. I don't want to lose data already stored in that.
Is the hard drive the primary hard drive with windows on it? Or is it a second hard drive on the system? If it is a primary hard drive and the computer can't recognize it, I recommend plugging it in to a different computer through a USB hard drive enclosure, you may be able to access the information on it by doing this. But if the drive is going bad, accessing the information is going to be a pain almost no matter what. You may also be able to go into the command prompt (start > all programs > accessories > cmd) and run chkdsk /r driveletter:
Mar 07, 2011 | Computers & Internet
After I turn on my computer I get a message that says; Primary drive 0 not found, primary drive 1 not found, secondary drive 1 not found, strike f1 key to continue, f2 to run the setup utility.
If you have a spare working hard drive to test in this computer, swap it out with the existing one. All you have to do is verify that a drive is found during the post. If you get the same message, I would suspect the IDE controller on the motherboard has failed. With the age of the computer (5 years), I would suggest getting a new or used computer to replace it. You may be able to find a replacement motherboard for it, but then to keep it legal with a Windows operating system, you have to locate a motherboard of the same make/model.
Aug 26, 2010 | Dell Dimension 3000 PC Desktop
All the time a computer is switched on, its operating system software has to stay in 1. Main Storage 2. Primary storage 3. Floppy disk 4. Disk drive
The operating system is usually located on the C: Drive. It can go anywhere..BUT.. most software will try to install in "C: program files".
So if you change the location on installation to somewhere other than C:, you may run into problems.
Main storage and primary storage are same thing.
Modern pc's cant run an OS off a floppy, but you can run a LIVE distribution of linux from your disc drive
If this is not what you where asking please feel free to clarify your request
Jul 10, 2010 | Acer Computers & Internet
Windows 7 won't start up when I try to install my dvd1260i . I followed the 5 step installation guide, and when I turn on the computer, it tries to run problem solver and says that there might be a...
You should remove your new hard drive out from your computer. Check your dvd drive jumper configuration. Make sure that if you use it as secondary drive for your primary drive like hard disk or etc., the jumper configuration is set to slave.And if you use the drive as a primary master, make sure that the jumper settings is set to master. Dont join both primary drive into one data cable, it will cause a drive error or one of them will not work. After that, install back your dvd drive into your computer.
Dec 23, 2009 | Electronics - Others
Problem with Dell Dimension2400PC
Hit F2 to run setup.
At the HDD set up portion leave Primary drive as it is.
Set the Secondry drive to none or automatic.
Nov 05, 2008 | Dell Dimension 2400 PC Desktop
I've installed a new hard drive and put in more RAM on my Desktop. Now i get this message WHAT DO I DO. The amount of system memory has changed. Primary hard disk drive 1 not found Strike the F1 key to...
Strike F2 to go to the bios to run the setup utility
Don't touch anything , save and reboot
If primary hard disk still not found
reboot press F2 to re-enter the bios
Look for Auto Detect Hard Disks
if the computer shows a hard drive is detected
set the drive to LBA if possible
save and reboot
Az.
Sep 15, 2008 | Computers & Internet
Hard Drive Failing?
It may be a virus or spyware. You can go HERE and run Trend Micro's Housecall on your PC. It's free.
You should also perform regular system cleanups and defrags on your pc.
Jun 25, 2008 | Computers & Internet
Computer won't run windows and come up with a trap-handler error
on the IDE Port, set the jumpers to the hard drives/cdrom on CS(Cable Select) this lets the BIOS and the ribbon cable decide which is primary (Master) and which is secondary (Slave) on that IDE cable. if they were configured wrong you would get an error.
If the IDE channel is no good, try switching the primary and secondary IDE ribbon cables.
May 26, 2008 | Intel Motherboard
CD ROM is not detect in My Computer
dtect your rom in bios
and try.
Apr 01, 2008 | Intel Motherboard
Computers & Internet Logo
David Payne
David Payne
