Question about Samsung SCH-a670
Speaker Volume Low
I dropped the phone and the speaker got hard to hear, as if something shifted. I opened the top portion of the phone thinking I'd see something obviously askew but saw nothing I recognized. My 5 year old later dropped the phone and it started working correctly again. I've since dropped it once more (I'll use the belt clip now when I'm on headset). Back to low volume. Headset volume has always been fine. Thanks
    Problem Solver:
  • 10 Answers
Open the mobile and realign the speaker back on its tracks it will work and reassemble it
Posted on Jun 20, 2006
Speaker too low, hard to hear. can i adjust volume?
What phone do you have?
On most phones there are buttons on the side to adjust volume.
There are also options for volume in your device's settings, under sound.
If it is hard to hear someone during a call you can turn on speaker mode which will make the sound a lot louder.
Oct 16, 2015 | Cell Phones
Sound card problem toshiba c55a
C55-A Toshiba , Low volume on my ear phones . Click on speaker icon . Click on Speaker icon, at top of speaker Volume . This will take you to Speaker properties . Select drop down menu in the advanced tab. I changed my bit rate until I found one that worked with my ear phones .
Dec 29, 2013 | Toshiba Computers & Internet
Hello, I have Nokia 6600 Slide handset with me. But, since few days i am facing a hearing problem with it. I could not hear to the voice of other end. Also, if i call some one i could not hear the dial...
i think the problem is in your speaker, but fist please check the volume of your speaker, if the volume is full and you can't hear it clearly, you need to clean or replace your speaker, to clean or replace your speaker you need to open the cover, it located in the top front above the lcd behind nokia brand, you need to open your front cover, if you can open it try to clean your speaker with a pencil eraser..
May 19, 2011 | Nokia 6600
My w595 phone speaker does not work , i can`t talk with other.
Play a asong to check whether the problem is with the speaker or the phone. If you hear the song when played through walkman then , Check whether the volume of speaker is low. for this make a call. when you see the call in progress on your display press the rocker keys on the side of your phone to adjust the volume of the speaker while making a call.
You can chage the volume by the roker keys provided with the symbol "+" and"-" Sony walkman series phones stores two different levels of volume for the call and for the Multimedia.
If the volume is full and still the sound wont come then follow these steps.
If you have the proper tools >>remove the battery. >>open the back cover of your phone >>open the front panel of your phone >>carefully unscrew all the screws visble >>now take out each part with care.(samo needs extra care while pulling out from the base board.) make sure you dont break the borad. now you gain access to the speaker near the speaker port. use an eraser to rub and clean the terminal s of the speaker as well as the mother board of the phone.(Dont rub too hard or else you will damage the phone) >>now put everything back and switch on your phone. You should be able to hear the sound.
if you still dont hear the sound replace the small speaker( you already know how to remove it as you have opened the case once) it wont cost more than 2 or 3 dollars.
if dont have the proper tools >>Go to the nearest dealer/shop and hand over the phone to them. Let them do their job. They will replace the speaker immediately. wont take long
Dec 02, 2010 | Sony Ericsson Cell Phones
My daughter has an lg 5300 phone - she can call but can't receive or hear the person she is calling..
The reason she can call out and the person she is calling can hear her is because the mouth piece is working perfectly.
The reason she can't receive a call or hear the person she is calling is simply because the speaker of the phone is faulty.
  1. remove the battery cover, the battery and the sim,
  2. Use the screwdriver or tweezers to gently pry off the RF grommet located on the antenna cap,
  3. then you can split the phone open carefully and try to locate the speaker
  4. by lifting up the panel below the speaker,
  5. carefully disconnect the speaker from the board,
  6. and replace it with a new one,
  7. reverse the whole procedure for reassembly
take care
Jun 18, 2010 | Cell Phones
Hard to hear - maybe dust in speaker? How to clear
As you mentioned dust may be one problem.To rectify this go to your nearest Nokia Care center & service the phone.
The problem may also be due to the low earphone volume.Please check your earphone volume to rectify this.
There is also a possibility of minor damage in the earphone unit due to which your not able to hear properly. You have to replace the earphone unit in this case.
Feb 25, 2010 | Cell Phones
Nokia 6600i speaker volume to low
Your earpiece mechanism is bad & needs to be replaced.
I have fixed numerous phones like that, even my brother has the same issue before.
go to a local repair shop to have it replaced.
Dec 16, 2009 | Nokia 6600
Speaker quit working
If you open the phone on your own it will void the warranty. My fiancee had the same problem with his phone. He turned it upside down and lighty tapped the speaker against the padded sofa arm. It instantly worked, by doing this the speaker contact was shifted back into place. If this does not work you should probably send it back.
Apr 29, 2009 | Motorola Mobility MOTOZINE ZN5 Cell Phone
Buzzing noise while making a call
This happens at many phones due to the speaker which buzzes because of the waves made by the conversation. For example try calling someone and be near a desktop pc speaker or radio and you'll hear the same buzzing noise
Feb 19, 2009 | LG Dare VX9700 Cell Phone
Samsung SCH-a670 Logo
105 people viewed this question
Top Samsung Cell Phones Experts
John Tripp
John Tripp
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
