On NBC channel we see moving dots across the picture. No other channel has this problem.
    Sergeant:
    Champion:
  • 334 Answers
Cue that cha farther away u need better antenna or turn antenna on hd ch or if uuse box they will have to dial u in better ok
Posted on Oct 07, 2008
Is Brad Pitt dead?
He is not, unfortunately. The net article is a scam which leads to a computer virus.
Oct 12, 2016 | NBC NEWS CHANNEL 4
What channel is nbc on vizio
The Brand of TV does NOT Change what order the channels are in. Channels are on the same channel no matter what brand tv you have. Look online for Tv with your zip code after it this will get you all your channels in your area. Or ask your cable provider for a channel list.
Oct 01, 2014 | Televison & Video
Had my channelmaster 4046 HD hooked up to a vizio tv and got all major channels. Now have hooked up my antenna to an RCA tv and can't get NBC and local FOX station is jumpy
The tuner in the RCA has poor sensitivity. Radio Shack sells a inline amplifier that may help, make sure you can return it if it doesn't. Move the antenna outside if possible and as high as possible, that may help. Good Luck!
Feb 14, 2014 | Channel Master CM-4046HD MODERNtenna...
Cannot get NBC on my channel master
Your signal strenght is too weak either try moving the antenna to a different location. If that doesn't work then you may need an outside antenna. The link below will tell you what stations are available at your address and what type of antenna is necessary.. TV Fool
We just purchased an Samsung Plasma model #PN50B1D
unfortunately these newer tvs do not display the standard definition analog channels very well. the picture gets better when viewing digital channels but doesnt display at its best untill u place it on a high definition channel
Feb 07, 2010 | Televison & Video
I can no longer get nbc on my converter box
try doing a rescan of the channels, might also be new RF signal obstruction in the area, try re pointing your antenna a different angle, this helped me once when a weak channel was freezing often.
Nov 17, 2009 | Insignia Digital-to-Analog Converter for...
I can't see NBC with the digital conveter box
Is it only NBC? Or are the other over air channels (ABC, CBS, Fox) also not seen?
Are you going through a splitter with the incoming signal? if so, make sure the splitter frequency range is at least 5 to 1000 Mhz.
You should see the 'temporary lost signal' wording on the channel. Check all cable connections to make sure the cable to connector plug are tight and not loose.
Oct 04, 2009 | Insignia Digital-to-Analog Converter for...
Don't get ABC or NBC local channels anymore
ATSC tuners ("D/A converters") pick up signals off the air just like old school television. It sounds like you are just not getting a signal of sufficient strength. A weak analog signal looks like a "snowy" picture, which most of us are used to. But, the new digital channels quickly go from a perfect picture to none at all. It's basically all-or-nothing.
Try attaching an antenna to your converter. I know you can buy a new antenna from your local big box electronics store which is labeled "Terrestrial HDTV" or something, but that really doesn't mean anything. You can use any old TV antenna. Even a quality FM antenna (with an F-Pin coax connection) may work just fine.
When setting up the antenna, keep in mind that different channels are transmitted from different towers, in different locations with different strengths. Move the antenna placement and position around (just like grandpa had to do). You may have to make a compromise to get the best signal for your favorite channels.
May 15, 2008 | Insignia Digital-to-Analog Converter for...
The TV is only showing half of the picture
Hi Bigtate,
There is not much for me to go on with your description but here goes,
I suppose you have a convential TV set with a glass picture tube and not one of the new types with the large screen slim style displays!!!
If it a glass type picture tube then the following assumptions are made.
I hope yopu have not shifted house recently and moved the TV around???
If you have its possible the Yoke (its a device on the neck of the Picture tube that controls magnetically the scanning dot) may have moved and only is letting you see half a picture...
This is a long shot but it could be the cause..
Now the picture is supplied to you by a fast moving dot of light (Black & White set) that scans from the top of the picture and moves very fast down to the bottom of the screen, then flys back to the top of the screen and starts all over again during this process the dot lights up the picture tube to provide you with
the picture you see... (On a colour set there are three dots)
Its quite a complex process and its all controlled by electronics inside the TV receiver.
If you are getting only half a picture then something is causing the dot to only turn on for the lower half of the picture during its write time to the glass screen,
You dont say if the half thats off is white or black, so there are many things that the service technician needs to know before even starting to look for this fault. During the dot doing its write cycle down the sceen, when it reachs the bottom and flys back to the top of the screen it receives a synchronous pulse from the TV station, and this TV signal is critical in making sure you see the same picture as is being sent from the TV station.
Sometimes this sync pulse from the TV station is very weak and so your picture may float up and down the screen trying to lock to the incoming signal.. this just may be your fault.. but you dont say if the half of the picture that you see is floating or not..
Your situation may be that your TV has partially locked to the station signal and your aerial may be problematic,
but then you dont say if its on just the one channel or all of your station channels. So there needs to be more analysis of your situation prior to a positive answer being provided....
Sorry I can be of more help...
From YUBEUT...
Nov 10, 2007 | GE 31GT660 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
